Plus 2 ++++++
For DSD?
Don't look past the soon to be released iDSD micro from iFi.
Based on the performance of its little brother, the iDSD nano, it should be a real winner.
But for ultimate DSD I have heard nothing but raves about the Lampizator.
Great reviews from the ESS based stuff out there too, but, they DO have a multibit stage in there. So whether you can still call it DSD? Well, some would argue. Not me. I don't have a dog in the fight
I personally don't have a problem with conversion to multi bit, as long as there is no decimation. I THINK that is the case with the ESS chipset stuff. No decimation. But I don't KNOW that. So as such, I stick to my original recommendations. iFi for cheap. Lampizator for more.
Andrew
Andrew,
Its not just decimation. There is Digital DSP type manipulation going on as well. The output can be very good, but it cant be "pure". Now, some will argue that purity is overrated. I am not among that lot.
What 'happens' inside an ESS shipset regarding DSD handling is known only by his designer / builder.
I own and exaSound e22 (ESS based) and it's an excellent DSD player, from 64 to 256, at half the price of the Horus. Not to mention PCM where it's also a champ.
You can get very different SQ from the same ESS shipset, but different DAC manufacturer implementation, mainly regarding clocks, USB interface, power regulation and power supply.
Also own a Playback Design DAC that is to me a reference for DSD.
I never listened to the Lampizator DAC (but I have to), neither the Horus.
I don't exactly know what "native DSD" means, but I believe Andreas Koch (Playback Designs) know what is, then I can compare!...
Roch
Roch
To what extent is the Lampi sound 'colored' by the tubes it uses?
I guess I'm one the lucky ones to have all 3, the PD MPS-5, Lampizator DSD and the Merging Horus! Life is good...
Now don't everyone ask at once which is better!!
Only one question Bruce. Do you have any other tubed gear in your playback musical chain?
Thanks,
Roch
Guys- Have decided to try DSD recordings- I currently have the Concert Fidelity preamp and DAC which I love- So I just want a DAC to play DSD recordings on my sound science diamond music server- Without spending a fortune which DAC do you recommend for DSD recordings only= thanks so much for your advice- gary
It seems this question is flawed. I do not understand why one would want a DAC that was only for DSD. I want a DAC that does DSD well, but it must also do do Redbook and everything else well too! I, for one, would not want to complicate my system in such a manner. Anyone else agree?
I have a Doshi Phono pre and Tape pre, but nothing in the digital chain.
Lampizator -> Pass XP-30 -> Pass XA-100.5 -> Wilson Alexia
Did you try to play the Playback Designs DAC trough your Doshi Tape pre (I don't know if this is possible).
My questions goes because there are tubes (thanks to the Lampi) in your digital chain.
Mine is:
Playback Designs SS DAC-> Conrad Johnson ET-5 (tubed) pre -> Conrad Johnson ARTsa (tubed) amp -> ML CLX speakers
Roch
