Good but cheap speaker cables.
Hxt1
89
3
913
Vancouver B.C.
I've been flamed for this before.... Anti Cables!!! I must admit that the Anti Cables were one of the most immediately noticeable improvements to my system...
I run single drivers, wired direct, no crossover... I have found them to be very revealing as far as changes to my setup/source material goes... going from Kimber 8tc to Anti Cable was like night and day! I actually couldn't bear to look at the 8tc's just sitting there doing nothing, so I gave them to a buddy of mine. No regrets.
I had to abandon the Anti Cable, as I re configured my room... I will go back to them someday.. I miss them.
Also, I recently switched to Anti-Cable IC's for my phono cables.... no complaints.
JackD201
1,429
1,820
Manila, Philippines
Why in the world would you be flamed for any cable? I guess I'm in the right forums :)
flez007
2,915
36
435
Mexico City
I have a couple of IC Anti Cables for testing purposes where I need long runs, no issues!
NorthStar
24,305
1,323
435
Vancouver Island, B.C. Canada
---Hello Hxt1 from Vancouver! :b
Whenever someone get flamed, it's because he ain't in the right space or at the right time.
It is your right, it is your space, it is your time; it's your opinion. :b
Cheers,
Bob
EDIT: Or it ain't the right person. ...You know what I mean; people with one-way idea.
No one fits that description here at WBF. :b ...Versatility of mind.
mullard88
948
62
1,588
In my system, I have discovered two good but cheap speaker cables. The first one is the flat ribbon type speaker cable by 47 lab. The second is the Daniel Hertz speaker cable.
GaryProtein
2,542
31
385
NY
Me :)
. . . . I have the same way of looking at cables as Gary (see his website)--[that's another Gary, NOT me] where the sound of a cable is not additive but subtractive. . . . .
I completly agree.
After using a number of speaker cables (but not the $40,000 ones I was more than once coerced into trying), I made my decision several years ago to go the heavyweight, anti-exotic route, and have not looked back even once.
I am using #4 AWG welding cable. 1634 strands hot / 1634 strands common, per cable. Very flexible and the most direct conduit from power amp output to speaker driver input. Nothing fancy to change or adulterate the sound.
Lee
3,256
1,781
1,260
Alpharetta, Georgia
Daniel Hertz cable is cheap?
JackD201
1,429
1,820
Manila, Philippines
Surprisingly they are compared to the rest of Levinson's new line.
GaryProtein
2,542
31
385
NY
The wire strands are like hairs, so the cable really is flexible, not like lamp wire, but easily bends like a heavy rope, and the actual wire conductor diameter stated by Don sounds about right. If he's wrong he has real chutzpah describing it to six significant figures! (0.518922 cm) :D :D :D
DonH50
Jun 22, 2010
3,969
333
1,670
Monument, CO
LOL! My only chutzpah was in the conversion; the diameter in inches is from the ITT's Reference Data for Radio Engineers (5th ed., Sams, 1968).
Curious -- Have you had the heads replaced in your Dragon?
GaryProtein
2,542
31
385
NY
I have to say I haven't used it in years, and it was actually not used very often even when I had it hooked up. I'm sure the heads are in good shape. Is there even a way to have the heads in them changed anymore?
DonH50
Jun 22, 2010
3,969
333
1,670
Monument, CO
Dunno', why I was curious. A friend of mine bought a new set from Nach stock many years ago but I was surprised to see one still running now. I know there are firms that will rebuild heads but have been out of tape for a long time. If yours has low hours, no worries!
/diversion - Don
mullard88
948
62
1,588
Hi Lee,
I don't remember exactly what I paid for my 9.5 feet Daniel Hertz speaker cables but in my recollection, it cost less than 1,000 U.S. dollars.
MylesBAstor
81
1,725
New York City
class a
70
Tellirium Q Blue $298 & Black $498 are excellent. I have the Blacks hooked up to my Aerial 6's and have been very pleased.
hifitommy
well, once again, i don't see how some of these cables can be considered to be cheap. what i have used that is cheap is the audioquest type 4. they replaced monster 12ga twinlead. at first i thought the bass was less but after listening a while, i realized that the bass was clearer and more extended. the monster was giving me more bass overhang and was tubby.
i never hesitate to recommend type 4 as an affordable but very good speaker wire.
dingus
108
2
Graham, WA
well, once again, i don't see how some of these cables can be considered to be cheap....
ditto, but i would use the term 'inexpensive' as opposed to cheap. my choice in speaker cable for many years has been Canare Starquad 4s11, well under $2.00 per ft in bulk.
