If I have a class A 300w amp, will it trip my power in a London flat if it doubles down to 2400w * 1 ohm? Of course here the class A drops to below 37.5, I think (300/2, 150/2, 75/2)
Assuming normal from the wall power
If you're using a standard 13A fuse in your plug then you'll be certainly be "close" at a nominal wall voltage of 230V (even though London voltage is often closer to 240) since I=P/V=2400/230=10.4A.
If the amp is actually outputting 2400W into 1 ohm, then the chances are it's sucking a fair bit more than that from the wall as no amps are 100% efficient. So yeah, it probably will blow a fuse in your plug at those levels. Will it trip the fuseboard? Probably not if its a 20A circuit, although I wouldn't be boiling a kettle in your listening room at the same time. FWIW I regularly blew 5A fuses in my power cables with a Krell KSA 80, although that was due to a switch-on surge.
Be interested to know which amp you have in mind . 300 w Pure Class A , would be one monster .
Symphonic line Kraft, used. The options in terms of 1 ohm ability and budget are that, Krell old FPB, Gryphon colosseum. All used
Of course you know that these amps aren't Pure Class A designs, they operate in Class A only at 8 ohms and it's Class AB at anything less. Given your choice of speakers 4 ohms is already a stretch! Also given the chassis size and operating temperatures of two of these amps I'm highly suspicious of their 300 watt Class A claims even at 8 ohms, that's why I asked earlier about the amps.
david
