Problem:
When the DAC is plugged in and the Amplifier turned on, there is a significant amount of white noise being heard. Removing this specific DAC removes the white noise.
Set up:
Speakers
ipedreams
Amplifier: Merrill Audio VERITAS Monoblocks
Pre-Amp: None
Dac: Memory Player
Interconnects are balanced.
No Power conditioners.
Items tried:
1. Floating the ground even though there is no ground loop hum.
2. Changing the outlets so they are totally independent from the DAC
3. Changing power cords
4. Did not change XLR cables - wish we had.
5. Did not try another Source, also wish we had however anywhere else this has not been a problem.
This had a very low, acceptable level of white noise when using the Audio Research VTM2200.
This was tried on one other Memory player with no problem so it is specific to the memory player (or the amps).
What could cause white noise like this? It almost seemed like a connection in the balanced configuration was missing?
I would like to see if anyone else has had any experience with this types of issue and how it was solved, if at all?
Is the VTM200 balanced inputs not truly balanced, i.e. has an active ground as part of the signal?
Set up:
Speakers
Pre-Amp: None
Dac: Memory Player
Items tried:
