Chuck this look likes a good place to apply some of the points raised in my thread what to look for in a power amp. Why don't you suggest a speaker? Two of the amps have been reviewed in Sterophile.
A high efficiency mini-monitor might be a good choice.
Some additional information could help, such as room size, music preferences, speakers considered, other components in the chain and personal tastes (analytic/musical, soft/loud volume preferences, etc.)
Speakers are PMC OB1's
Room size is 12x20
Music preferences are - Blues, big band, jazz, rock, and a little classical
Music Volume - typically lower, with some louder sessions, but not blow the windows out loud.
Pre Amp - McIntosh C2200
Rega TT
Music Server, and DAC
I have the MC275, and have heard a BAT 35 watt tube amp. Haven't heard VTL yet, but I know a few folks who rave about them.
I am curious if anyone has any experience with any of the three amps, and any advice you might have.
I tend to stay with SS but have used hybrid to good effect in the past.
If there was one tube pre/amp combo I would had loved to listen it would be the McIntosh 60th anniversary pre and power amp.
For the specification and measurements it is quite an incredible combination at what I feel is a good price; expensive but nowhere in same league as some of the high end.
Still surprised it was never reviewed in Stereophile but thankfully its profile was raised over here in the UK.
Ah well shame as it seems one of their best products to date
Consider buying two VTL's still the least expensive
Mcintosh a classic tube amp.
BAT is the winner. Class A,600 joules energy storage.Fully balanced. Superior build quality. As usual it is the most expensive. Add to that you need to to get the VK 5 preamp and probably another VK 75SE and run it in bridged mode. Now you need to go Listen. That is the only test that matters for the end user. MAy only concern is the BAT high output impedance that could cause problems with linearity. Nothing's perfect.
Other suggestions- Class A tubes Atma-Sphere MA 60. Hybrid Aesthetix Atlas, Moscode 402AU. SS Harmon Kardon Integrated HK 990. Good Luck.
BAT is a good choice. Maybe also try some of the ARC amps. The Ref 110 is very nice and some of the older designs like the D115 Mk 2, D70Mk2 or maybe the VT130 would be worth a look. I think if a budget is a concern, then the D70mk2 and/or the D115Mk2 are very hard to beat for the money.
We recently AB'ed my D70Mk2 with rolled in tubes against the VTL St 85 and the BAT VK 55, everyone that day preferred the D70 and by a wide margin! YMMV.
I had an opportunity to purchase a Cayin MT-12 tube IA yesterday, and was interested because the person selling this small 12wpc amp had Totem Forrests running off of it. Totem's aren't the most efficient of speakers, so this lit me up.
Until now I had never considered looking at such low wattage units, but I guess they are powerful enough in a small room such as mine (11x10).
What's your opnion on these types of units?
John
PS: Some one beat me to it....and I'm kinda disappointed.
