Please, give me your experience on what you hear when tube life is about to end. What are the signs? Are they different from equipment to equipment, ie., Phono, amps, pre amps.
Thank you very much.
Tang
This is an easy one to answer....a significant increase in noise. That noise can take quite a few different forms, but it will always be noticeable. I don't think the type of equipment has anything to do with this...noise is what you are going to hear.
OTOH, there is always that quick flash and then instant death....but that's not really what your question was about.
Many years ago, when I had an Audio Research D115/MkII amp with 6550's; the end was signaled not by an increase in noise, but with a sudden, terror inducing explosive retort and smoke, and then an expensive trip to a local shop. It was enough to instill fear and loathing in my heart about tube amps.
I think it was a post from the Doc that made a lot of sense to me... Often the diminishing sound as tubes age is so gradual that the only way to really be certain is that if you suspect that the time is near, put in a new set. If you hear a difference leave the new ones in. If not, then put the old ones back and continue listening.
Dear DaveyF,
May I ask what kind of noise. The noise that comes from the speakers. Or the noise generated at equipment?
Thank you for your advice.
Tang
Many years ago, when I had an Audio Research D115/MkII amp with 6550's; the end was signaled not by an increase in noise, but with a sudden, terror inducing explosive retort and smoke, and then an expensive trip to a local shop. It was enough to instill fear and loathing in my heart about tube amps. I did later enjoy great service and sound from a pair of Wolcott Presence p200 mono blocks which simply notified the user via a blinking LED of a misbehaving EL34 at the end of the auto biasing process at turn on. You could simply replace the worn out tube. No need for matched pairs! I suspect most modern tube amps don't explode at end stage, but nonetheless, I have moved onto SS with Pass Labs and couldn't be happier.
Thank you Phil, DaveC, Iamrae, DaveyF and Jack.
I am hearing some kind of distortion that annoy me these last few days. I played with different arms, tts and they all not up to the sound I used to enjoy. I was playing with the same phono. This phono I have about 3,000 hours on. I suspect it is the phono.
Kindest regards,
Tang
You have too many TTs, arms, and carts, but not enough phonos, that's the problem I think
Maybe the problem is I turn on my system 7:30 am and shut down at 4:00 pm every working day and I haven’t changed any tubes.
Kind regards,
Tang
Am i to presume that your gear has all of the stock tubes in it? If so, look into tube rolling, you will most likely get a nice uptick in SQ. Be careful, it can be very addictive though, LOL.![]()
