What Cartridge Alignment Protractors Are You Using?
jadis
12,829
5,932
2,810
Manila, Philippines
Hi, hope to open up a discussion on cartridge alignment and use of protractors out there in the market. While my own tonearm has only a ruler supplied by ET to align itself, I have a Dennesen Soundtracker which I use to help my friends align their pivoted arm. An opening question would be 'Would different protractors register different null points?' Or to put it in a another way, suppose I have set a null point based on the Dennesen protractor, should or would the null point be different if I counter check it with say, a Feikert proctractor or other protractors?
HI Phil,
Like you I have ET2.5 arm's. Unlike you I have the ET mounting jig which provides alignments for the most important variables. I remember when I bought my first ET and I was dithering about buying the jig. As I remember, it was about $250 and the arm alone was around $1100 in 1990 which means the jig was relatively expensive for my stretched budget. Boy, am I glad I bought it. They are like hens teeth to buy now and ET no longer makes them.
My Graham 2.2 Deluxe on my Thorens TD125 does not need a jig. Bob Graham (warning; I love to drop names!) did a wonderful job designing the alignment tools provided with the arm. Nothing else is needed.
So, I have no need for alignment protractors.
Sparky
HI Phil,
Sparky
There is no better cartridge alignment tool than the Graham!
If only Bob would design ones for other arms. Five mins at worst to align for zenith and overhang. Best of all, it makes setting up those cartridges with round/non symmeterical bodies or short cantilevers a dream. But Bob unfortunately won't.
HI Phil,
Sparky
Hi Sparky,
Yes, the jig is quite essential for us ET2 users. The dealer who sold me the arm had a jig when he installed my arm.
That's true, Myles, I've seen Jack mount his Jade on his Phantom in minutes. Maybe 4. ;)
With the caveat that I haven't tried all of them out there, I'm a big fan of the MintLP protractor. Really helps to optimize alignment better than any of the other tools I've used. That said, I suspect that this subject is like many in audio; the best tool, is the one that gives each individual the best results.
Hi jacdoc,
I have heard about the Mint LP protractor. A very good friend uses one. And also has a Dr. Feickert protractor previously. The MintLP protractor is made specifically for a particular brand of tonearm and cartridge, he tells me. I asked him how different the null point or other adjustment parameters were between the 2 protractors and he said the settings are not that far off, which I believe, theoretically speaking, should be the case.
Phil,
One minor note, the MintLP is specific to the TT and arm combination; not the cartridge. I've used the Feickert but have had better results with the MintLP. It definitely takes some practice to use. Again, the best tool is the one you get the best results with.
No one uses the Wally Tracktor?
Phil,
Thanks for the correction, Doc. I may have heard it wrong there. My friend is very happy with his MintLp aligning his TNT and Triplanar.
One thing I forgot to mention; Yip at MintLP is very responsive and easy to worth with...
I have platypus fingers, make it 6 minutes ;) ;) ;)
Swapping wands takes about 3
Awesome, Jack. ;) And you're the only one who I've seen with a Phantom armwand and cart with protective cover snugged in the left breast pocket of your shirt. Reminds me of 'Gunsmoke'. DRAW !!!! ;)
I used to use the Wally Tractror with my VPI, then Mint and Feikert.
Now I use the wonderful German made Uni Tractor.
the best i have used. I use Daniel's own alignment as it sounds better than Loef, Baer and Steveson to me
http://www.audiogon.com/cgi-bin/cls.pl?anlgtnrm&1320764329&/Uni-Protractor-Set-tonearm-ali
I use Dr. Feickert's latest protractor. I like the arm that locks onto the pivot point when I do my overhang and zenith angle adjustments. Haven't gone through the effort to try a Mint. In fact I don't believe mint has one available for the Clearaudio Universal arm.
