Volkswagen XL1 Concept
It gets a VW-estimated maximum of 261 mpg—and it's going into production.
BY RAY HUTTON
http://www.caranddriver.com/reviews/volkswagen-xl1-concept-first-drive-review
I hope Sly is available. It's been years since Demolition Man.
First drive: 261 mpg Volkswagen XL1
By Paul A. Eisenstein, CNBC Contributor
t takes a bit of effort to slip in under the gullwing doors and then wedge oneself into the low-slung seat of the Volkswagen (XETRA:VOW3-DE) XL1. And it's even more difficult for my co-pilot, as the passenger seat is set slightly rearward, almost tandem-style.
The simple reality is that the windswept two-seater isn't built for comfort. The Volkswagen XL1 was designed for maximum mileage. And we're not talking something like the mere 50 to 60 mpg of today's best hybrids, nor the 100 mpg "equivalent" ratings of some of the latest battery-electric vehicles.
No, this diesel plug-in hybrid recently received a mind-boggling rating from European authorities of 261 mpg, far and away a record.
Describing the XL1 as "my baby," program manager Steven Volckaert noted the project has been underway for more than a decade, with the original goal of squeezing out 100 kilometers from a single liter of fuel. For the metrically challenged, that works out to about 235 mpg.
VW revealed its first attempt in 2009, a tandem-seating concept dubbed the L1. With a somewhat more traditional interior layout-and even better mileage, the XL1 made its world debut at the Geneva Motor Show last February.
But what came as a shock was news that VW would actually put the extreme machine into production, albeit in limited numbers, a year or so from now. Specific details have yet to be worked out, including the price.
It's likely to rival that of some of the German maker's more luxurious models-but even then, the cost almost certainly won't come close to covering the actual cost of building the XL1, even if the mileage champ were to start rolling out of the factory in the same volume as more mainstream Volkswagen models like the Golf.
No surprise considering what it takes to achieve 261 mpg.
There were three key elements to the project:
A superlight chassis and body;
Aerodynamics on the order of the most advanced aircraft; and
An ultraefficient powertrain.
The VW XL1 is primarily made out of CFRP, or carbon fiber-reinforced plastic, the same exotic material used in Formula One race cars and the most extreme sports cars like the Volkswagen Group's Lamborghini Veneno. There are other light materials such as magnesium wheels and ceramic brakes, and clever engineering reduced the parts count so only half the normal front cross-member is needed.
The results are impressive. The monocoque, or passenger cell, weighs in at just 197 pounds, with the entire vehicle at a mere 1,753 pounds.
A variety of wind-cheating tricks also play a role, including full underbody panels and instead of conventional side-view mirrors, the XL1 uses a pair of tiny cameras that display images on LCD screens built into each door.
But the heart of this high-mileage beast is a minuscule 2-cylinder, 0.8-liter 48-horsepower diesel engine paired with a 27-hp electric motor drawing power from a 5.5 kilowatt-hour lithium-ion battery.
The plug-in system will deliver a nominal 32 miles in electric-only mode, though for longer drives, or under more aggressive driving conditions, the diesel will fire up.
For now, as I hit start, the diesel is idle. The only way to tell the XL1 is ready to roll is by reading the gauge cluster visible between the steering wheel. Putting the dual-clutch manual into gear the little car lurches forward, the only sound gravel crunching beneath its narrow, low-friction tires.
As we weave through traffic in Wolfsburg, VW's German home, the XL1 draws plenty of stares from pedestrians and other drivers. The car is so small it's easy to maneuver city streets and though the XL1 has no power steering-too heavy-it's so light as to be surprisingly nimble.
On local roads, there's little trouble keeping up with traffic, though the real test comes as we turn onto the A1 Autobahn heading toward Berlin.
The good news is that with the vehicle so light, its compact powertrain delivers quicker acceleration than one might expect. It's no rocket but it's quicker than some classic econoboxes that might otherwise leave you fearing for your life on the unlimited German freeways.
Of course, the diesel has finally fired up and, well, no matter how much VW ultimately charges when the XL1 goes on sale you won't confuse it with a similarly priced luxury car.
To save weight, there is almost no sound insulation so the cockpit echoes with the oil-burner's clacking. Happily, as we exit the Autobahn it quickly shuts down and our ears get a respite as we return to battery power.
We can only hope that VW planners opt to sacrifice a few pounds and a couple mpg when the two-seater goes into production. Even if it "only" delivered 255 mpg in final trim would potential buyers be disappointed? Unlikely.
In fact, a final check of the gauges as we pull back into VW headquarters shows that we've been averaging a more thirsty 1.8 liters per 100 km, a mere 138 mpg, due to spending so much of our time racing along the Autobahn under diesel power near to the XL1's top speed of 99 mph.
That said, we'd still be able to make the run from Berlin to Frankfurt-or Los Angeles to San Francisco, for that matter-on well less than three gallons of fuel.
VW expects to produce just a couple hundred copies of the XL1, enough to log some real-world data about the various technologies the little car uses.
In the years ahead, however, we can expect to see the design influence more mainstream products as the industry struggles to meet increasing mileage and emissions standards around the world.
While 261 mpg requires some real sacrifice from driver and manufacturer alike, the Volkswagen XL1 should help engineers and designers figure out ways to deliver significantly better numbers than the typical automobile delivers today.
That doesn't read as a practical car in my book. I am a Diesel fan (Own and have owned several Diesel cars including a VW) but For that kind of money, I would get a Tesla and be done with.. Well to put it in other words. A Tesla is in the horizon ;)
