The tech who has been working on my tape head pre amp thinks he will have completed it by the end of this month. The reason it has taken months was, early on I let him know I was in no hurry and wanted to give him as much time as he needed to work out the circuit and related details. Now that he is almost done I had at least one concern .... Where should the trim pots be placed?
The tech (Mr. Amina) sent me an email stating he was finalizing the pre amp and had placed the trim pots on the front of the pre amp. He thought that was a mistake. The pre amp will have a separate power supply and will be encased in wood. I suggested he might want to place the trip pots on the top which is metal. Then, it dawned on my that it might be important to be able to adjust the pots while the music is playing which would mean this would be made easier if the trimmers were placed on the front of the pre amp. I thought this would be preferred because some tape-o-philes might want to place the pre amp on a middle shelf in the audio system. Mr. Amina may decide to sell this pre amp on his website to other tape lovers later. Is so, placement of the trim pots may be important.
Most here on this forum have used or been exposed to one of the outstanding tape head pre amps available. Tell me if it's important where the trimmers are placed and if it's important to be able to make adjustments while listening to a tape? Thanks all and I would appreciate all suggestion and your experience.
jazzbo
