Sony TTS 8000 or 6000 - please help me
Loheswaran
470
123
348
Dear WBF'ers
Do any of you have a Template for the Sony TTS 6000/8000 (same template) I am about to build a plinth.
If so would you be willing to kindly photocopy it and send it to me? I am happy to pay.
Thanks
Lohan
From pics online it looks like it bolts in from the top. Should be a piece of cake compared to a Technics SP10. I would just take a thin piece of cardboard and trace out the bottom of the table. Cut out the circle, then just put the bottom of the TT through the hole in the cardboard and trace out the top part. No need for a template.
Unfortunately it is angled, the front comes out and is angled. I have considered tracing already
Hi Daytona
Already got the manual from Vinyl Engine, but it does not contain the template :(
That said someone on Audiogon has sorted me out on this:cool:
As a result (Mr Admin) I think I can close this thread now.
BTW Daytona - I like ur interesting choice of turntable - how are you getting on with it? You got it fairly recently didn't you? What are the adjustments on the Helius like
thanks
I heard a Saffire at the high end show driving some large single ended amps and some art audio speakers and was very impressed - was it an improvement over the Helius Alexia?
