Question about a set up (KEF - Onkyo)
cavalerox
1
50
Hi,
As I have little knowledge around this topic I would like to ask a question and seek advice.
The system that I am about to buy is made of
-Onkyo TX-NR 6050 receiver
-KEF - Q Series 6.5" 2-way Bookshelf speakers (pair)
-Audio Technica ATLP60 XBT Bluetooth stereo turn table
1) the receiver model and brand I wrote would work fine with those speakers?
2) the turntable would also run with the receiver I hope. is this fine ?
3) what kind of subwoofer would you recommend that works well with this receiver and speakers?
I checked the nearby stores where I live and these are the available products it seems I can choose from that fits my budget:
Polk Audio PSW108 10" Powered Subwoofer
Polk Audio PSW10 10" Powered Subwoofer, 100W
Polk Audio - React 7" Wireless Subwoofer
Klipsch - Reference Series 10" 150W
Thank you all for your recommendation
Cheers
Hi,
Cheers
Hello,
1. Yes, they are compatible. No worries.
2. Yes, your AV receiver has a phono input. No problem here.
3. What is the size of the room?
Cheers,
