PranaWire Vajra SE power cord - 2 meter - 15A IEC
Justlisten2
5
PranaWire Vajra SE 2 meter power cord with Linebacker and Super Enhanced Ground Plane Technology.
This is one of the best power cords that I have ever heard or owned.
Now you can own one of the best for less than 25% of it's price when new!!
MSRP - $8,200; Asking $2093.57
Vajra SE- 7 gauge 99.9997% pure copper/silver hybrid - Enhanced Oyaide M1 and F1 AC & IEC Plugs, massive vibration control and EMI / RFI control with Linebacker and Super Enhanced Ground Plane* technology incorporated.
This cord has the Linebacker SE power filtration included on the cord. The Linebacker SE alone sells for $2995. Here is what the Linebacker does:
The Linebacker is a completely passive in-line power filter that works on several major fronts:
• It effectively absorbs massive amounts of parasitic and self-generated noise on power cable lines and prevents it from entering into the component it is plugged into
• It prevents environmental noise from entering the system through the mains
• It's maximally damped structure and cable quell cable, connector and airborne resonances before they enter the system.
This is accomplished by means of:
• Satori Power Cable design (7 gauge Silver/OCC copper conductors) whose internal architecture and materials implementation are inherently noise canceling
• Custom damped Oyaide F1 IEC Female Connector
• Highly damped chassis and IEC Male connector
• Massive amounts of carefully chosen noise absorbing materials
• Super Enhanced Ground Plane (SEGP) to absorb noise away from the ground plane of components on select models
The Linebacker will remove noise that you did not even know was there and render an extremely solid and palpably holographic sound stage. Bass is dramatically improved with new found focus. The Linebacker is a truly transformative device!
Thanks for looking and please check my other ads. PayPal adds applicable fees.
See pictures in my ad on US Audiomart, member Justlisten2. Also have feedback on Audiogon as member jmcgrogan2
