Power filtering – Furutech or Puritan Audio?
toronto416
11
11
3
66
Toronto, Canada
The Puritan Audio PSM 156 is getting a lot of love lately, but what about old stalwarts such as the beautifully constructed made in Japan Furutech e-TP80S NCF AC power filter & distributor for 2 channel audio?
If it works for you go for it.
I'm looking for a modest but effective power filter in a second system, more modest than the Accuphase PS-530 in my main system that replaced a PS Audio PP12 power regenerator.
Hence why the passive Furutech and Puritan Audio products come to mind for both power filtration and surge protection.
I agree and Furutech is fine equipment and will get the job done at a very fair price. I have used them in the past and have never had any issues with them. I am using the IsoTek V5 Corvus and I am quite pleased.
Open detailed view
Reactions: toronto416
I finally had a chance to test out my new Puritan Audio PSM 156 in two of my systems.
The effect of the PSM 156 was very apparent - a silent black background with clearer ambient sounds from the room acoustics in the recording, improved clarity, detail and soundstaging. It felt like a veil had been lifted between me and the musicians. I heard new subtleties in very familiar recordings and greater detail with less smearing of the edges of the high notes of the piano and soprano sax. Certainly a big improvement over no power conditioning or filtration.
I then compared it the PSM 156 to my PS Audio PP3 and PP12. The PSM 156 clearly bested the PP3, but the PP12 was much closer. The PSM 156 was a little smoother sounding than the PP12 with slightly cleaner articulation of the high notes of the piano. I would give the PSM 156 the edge over the PP12. They both sound good, but the PSM 156 sounds a little better. It is not really a fair comparison because my PSM 156 is not broken in, and the PP12 is. The PSM 156 is bound to improve.
Reactions: djsina2
I replaced both P15 and P20 with Puritan 156 mainly because the regenerators were causing an annoying buzzy noise in my room.
Do a test, plug only the DAC into the Puritan and the rest of your front end into the P12. You might be surprised!
