I am thinking of adding the audience power conditioner the aR6TS or aR6TSS to my setup has anybody tried it and what was the difference it yielded.help to decide.
I live in East Tennessee. There is a fair number of heavy manufacturing plants within the area, one that I used to work at as an EE. Such industry puts notches and spikes onto the line voltage. These, and harmonic distortions caused by uneven three phase loads cause all sorts of problems on the power grid.
Many "power conditioners" have elements that can suppress a spike, but not put it back in line with the sine wave. None of them, that I am aware of, can fill in a notch in the sine wave. As far as harmonics, conditioners are lost.
I use a power regenerator. It was the only thing that made sense to me. But, depending on what problems you have in your incoming power other conditioners might give you great results.
I can't tell. They say, "waveform shaping technology" but that doesn't say a separately generated sine wave. It isn't clear to me. I understand, and share, your confusion on that point. However there is another quote, "The reference signal generator" which makes me think that there is a reference input, like to a Mono amplifier putting out a sine wave.
All I can say is I'm confused as to what it is.
Hold on, I opened the PDF catalog and the text says it adds to or subtracts from the incoming waveform to make it perfect, a replica of the "reference." So it isn't a regenerator.
I use the Audience Adept Response aR6-TS power conditioner and I love it! We had a shootout at a friend's house that was reviewing the Nordost QRT Power products, and I brought my Audience and another distributor brought several others including the Bybee Power Purifier, Silver Circle Pure Power One 5.0se, PSAudio P5 Power Plant and Sunny Cable Power Conditioner. We spent the better part of two full days auditioning and comparing the conditioners. It was amazing how different each unit sounded. The Audience had by far the best bass dynamics and pace. The others sounded bogged down in comparison. Overall dynamics were also beyond reproach. The Silver Circle sounded at first very organic and easy to listen to, but the next day for some reason, it sounded forward. Can't explain that one, but it continued to sound forward and a bit bright from there forward. The top two in all three of our opinions was the Nordost and Audience. The Nordost was very inviting and smooth sounding, but in my opinion, lost some overall dynamics and bass resolution.
Keep in mind that the Audience needs big-time break-in! It wasn't until I had the unit on for two straight months that it started to show what it can do.
Caveat: I am a dealer for Audience products and would be happy to let you borrow my unit to try if you end up buying from me.
