$22,000 for two 15" drivers inside an aluminum sub enclosure!
And $36,000 for the 18 inchers! ...570 pounds!
Magico is doing la grande sortie with their new subwoofers.
2" thick aluminum front baffle; is aluminum that expensive? ...Is that healthy, and legal?
Are there different grades of aluminum, seriously?
The use of the industry accepted term, "grade" is a little misleading because it implies that one is better than another. "Type" would really be better than "grade". For example, titanium has about 25 "grades" that I aware of, maybe more, and one isn't necessarily intrinsically better than another, but one may be better for a given application than another. Again, specifically regarding to titanium, there are four grades of "pure" titanium, but grade 1 is by far the weakest and grade 4 is the strongest. If I were having a titanium prosthesis, I would want grade 4, the stronger of the titaniums even though it is actually less "pure" than grades 1, 2, or 3. Other alloys of titanium with higher grades may be better for aircraft designs but not for biological ones. The same holds for aluminum and steel. Different materials are better for some applications than other.
Krell also manufactured an 400 lbs aluminum subwoofer having two 15" woofers fitted with accelerometers and and an active feedback system, the Krell MRS Master Reference Subwoofer.
Those subs were monsters and weighted a ton. I had pictured one during my visit to Krell factory back in 2007:
[/IMG]
I belive the biggest problem with the Krell LAT1000 was fairly inexpensive tweeter used, sourced from Vifa. I have never understood why they had chosen that particular design over the much better ScanSpeak unit.
Perhaps you are addressing the older LAT1 - the LAT 1000 used the Scan-speak Revelator ring radiator drive, a similar unit to the one used in the Sonus Faber Stradivari.
