Nedd help for SF Guarneri Memento
dtm
2
Hello guys,
I am a happy owner of Sonus Faber.
Cremona M & Guarneri Memento.
My Guarneri Memento are very sensitive to the ambient temperature.
In winters, in one of my rooms, it does not make more than 14 ° C.
High frequencies appear to be matt
In summer everything goes in order.
I think the ferrofluid is a bit " frozen " when it's cold.
I will therefore remove the tweeter to check the condition of the coil and eventually replace the ferrofluid.
I often remove the speakers on many speakers and this is easy.
On the Guarneri Memento, it is impossible to remove this one, once the screws are removed, the speaker seems glued.
Has any of you ever done this work on this model?
Is there a special procedure for removing the speaker?
Thank you in advance for your help.
DaveyF
6,129
181
458
La Jolla, Calif USA
Hello guys,
Hello dtm, having just read your post,and as an owner of the Guarneri Homage....I would Absolutely NOT try and remove the tweeters! I cannot think of a reason why the ferrofluid should be touched or for that matter why it would be impacted to such a degree by the temperature that you are reporting.
I would suggest that you look at other possible issues upstream as the cause of your problems. Lastly, if all else fails, a conversation with your Sonus Faber dealer would be warranted....just do not take the speakers apart before this!!
dtm
2
Hello DaveyF,
Thank you for your answer and your advice.
I have tried the Guarneri in several of my systems and with different cables.
The problem remains the same.
It sometimes happens with a tweeter that the ferrofluid becomes hard with time and reduces the efficiency of the speaker.
I have several systems and these speakers are installed in a room where the deviations of temperature are important, besides I listen to them only a few hours a month, which accentuates the effect.
So I really think the tweeters do not work properly.
I would like to do this work myself because it is very difficult to find a serious and meticulous repairman.
Even through its distributor, generally the devices are entrusted to small independent repairers who do not take care of the material entrusted to them.
Only possible solution for me, send them directly to Sonus Faber in Italy, but it would be quite expensive.
Again thank you for your advice
Best Regards
dtm
DaveyF
6,129
181
458
La Jolla, Calif USA
dtm, I don't know where you are located, but you should try and contact your 'local' SF dealer...or at least someone that is connected with the manufacturer before attempting repairs...like I said before. Even if that means contacting SF in Italy for their advice. You are assuming that the tweeters have failed, which while possible, is not by any means the only cause for your findings. The SF GM's are not that old a design that the tweeters should have failed due to age. OTOH, IF you have blown your tweeters with too much power or some other type of issue, then repairs may well be necessary....I would suggest by an authorized factory rep only.
mullard88
948
62
1,588
Hi dim,
Would you be willing to subject the tweeters to blown with warm air from a hair dryer?
Al M.
8,779
4,539
1,213
Greater Boston
