yes you´re probably right
funny thing is my friend gets error code 10
and according to other contact the list only contains 9 error codes!?!
weird
best
Leif
I had responded to Leif, and he had forwarded the info.
For the future Nagra T-Audio fans with same Error Code 10, here's info on Error Code 10:
Error 10 is for the keyboard RS422 error. Make sure you have connected the cables correctly to correct ports and set the front dip switch to RS422 19200 baud.
when I got the manual and all the tips over to my friend he pushed it on to some local service guy in SR(Swedish Radio)
well se if he solves it....
thxs so far....
I´ll stick to my A80s
very true and I´ve had to really restrain myself from falling in the Nagra T "pit"
I also happen to have some shitty experience with Nagra "management" in Europe reg some VPA amps and will not have anything to do with them...
