Micromega M-150 + Melco USB / how to control
Xymox
464
417
170
www.appletvx.com
Im USB stupid apparently..
So a Micromega M-150 hooked up USB to the Melco N1Z EX shows the files on the Microimega app, but pressing play does nothing.
What am I doing wrong ?
This all works if I go Ethernet minim server, but USB is not in use.
SO I guess I am a USB noob....
So.. Obviously I need a program, or something, running on the Melco that will play and stream out the USB. This would need a driver that understood the Micromega as a audio output device the Melco could use.
Then a app could control this program running in the Melco.
So that would be Twonky ? The Melco also does Minim but that does not output USB, only Ethernet streaming.
So the part I dont get is that when Twonky is used with just the USB connected pressing play nothing happens. The transport controls don't work.
So what am I missing ?
Did you solve the problem?
