Marantz SA-10S1 Sound Quality Improvement
Phillyb
162
134
948
I found out something about getting the most out of this wonderful unit. In the settings section, I reviewed the setting and made sure everything was turned off that was not needed including the dither setting to off. When I got to HP gain out setting it was on high, not that I use headphones but I just wanted to set it to low, when I changed it from high, medium, and too low, the sound changed and I'm using the XLR outs to my Luxman C800-F preamp. The sound when from very good to oh my god, everything improved from the highs to the lowest of lows, there was more body and warmth, deep bass, and airly and extended highs. I repeated this several times and every time depending on which setting it affected the sound output. So if you own this unit or the lower model the Ruby, you might want to check this out for yourself, because the change in the HP gain section is impacting the final sound you hear from the unit.
I'm still amazed by my SA-10 in combo with the PM-10, daily.
For a few months, I've been enjoying filter 1, dither off, and the noise shaping 3rd 1 settings. Sounds perfect to me.
As you suggest, I have everything turned off that doesn’t need to be on; digital outputs, headphone amp off in addition to to lowering gain to “low“ though i‘d think it wouldn’t matter with it set to “off.”
Rn, Great. Try setting the HP gain to high and listen again to 30 seconds, then medium, then low of a track you will hear the difference why I do not know but is impacting the sonics.
