Manual for TechDAS
phoni
74
56
85
Hi,
I'm looking for the manual for the Air Force Premium III. Is there a download for this?
Tkanks
As far as I know, no.
What do you need to know? May I can help.
Regards
Florian
I have the AF1 if that might help
I have an AF3 operation and AF3 setup manual on PDF. Not sure how to get them to you thru WBF, however.
Hi CJmooney,
great, please upload the PDF to Dropbox and the download link thu WBF!
Thank you!
phoni
Hi CJmooney,
Thank you!
phoni
Please consider, manual for AF3 and AF3P is in some points different.
Setup both in December. There small differences in Set up.
Regards
Flo
Regards
Flo
I'm thinking about buying the Premium Rigid as an alternative turntable. However, it is unclear to me how often the filters need to be replaced. I haven't found any conclusive information on this yet!
Which filter do you mean? The sealing lips of the plate? Or you mean the pump?
The TechDas turntables are maintenance-free
Kind regards,
Florian
I'm talking about the air condenser unit inside the pump/power supply
Is not described for maintenance as far as I know.
Cheers,
Florian
Hi CJmooney, would you be able to share a link to download the AF3 operation and setup manual? Looking to purchase a pre-owned unit and wanting to get a sense of the setup process ahead of time. Thanks
If AF pump similar to Micro seiki pump in any way, i wouldn't worry about filters at all.
But it's interesting what inside the AF pump/psu box.
There are three 1 micron filters on my turntable/air pump. One on the intake and 2 on the exhaust. Otherwise, due to the air bearing tonearm, the air bearing itself from the platter is not critical, especially not on the TD turntable, because it has even greater tolerances than mine.
Sorry, I don't have or use dropbox. Can you give me an email to send them too?
Thanks for your feedback, in the meantime I have decided against the TechDAS and opted for a Kuzma XL DC!
