LAMM Repair in Los Angeles
jeff1225
3,161
3,525
1,970
53
Hi All,
So while listening to my LAMM 2.2's with the great NOS tubes...the right amp turned off and I cannot get it to turn back on. Switched tubes, switched fuses, wires, powercords, etc....its DEAD. Is there any repair company in LA that you all trust, I'd hate to have to air ship it to New York.
Thanks!
Hi All,
Thanks!
Your last choice IMO is your best choice
Have you checked your wall boards to make certain a circuit breaker wan't tripped there
Wall boards? Are you referring to the circuit breaker for my electrical system? I unplugged the sub amp from my speaker (which are working fine) and plugged it into the amp with no effect.
I agree with your not wanting to send it back to Vlad however thats what I have always done
Hi Jeff,
Couple of questions, are you using aftermarket fuses? Did you try disconnecting the speakers and the input IC then try the amps?
david
Hi Jeff,
david
David,
Thank you for chiming in here. I'm not using aftermarket fuses, and I switched the fuse from the dead amp to the functioning amp to make sure it was not the fuse causing the issue. When I switch on the amp there is a click, then the usual second click that begins the start up cycle when the LED usually starts blinking, but the LED does not come on. If I pull the power cord from the back, there is an internal click so I know the amp is getting power.
I'll call Vlad tomorrow morning and see what he thinks.
Hi All,
Thanks!
EASY: Just jump on the I5 & cut over towards San Jose. This guy is great.
True Sound
Nick Gowan
136 Kennedy Avenue
Campbell, CA 95008
Tel 408-370-7578
Fax 408-370-7581
gowan@tsound.com
Very surprised you California guys do not know him.
Now if only I good find a great tube guy around Seattle. CHIME IN.
zz.
True Sound
Nick Gowan
136 Kennedy Avenue
Campbell, CA 95008
Tel 408-370-7578
Fax 408-370-7581
gowan@tsound.com
zz.
I've used him in the past for an Audio Research upgrade. He is good. He did it while i
waited.
jeffrey,
I have experience with the Lamm 2.1s and there are strong similarities between our amplifiers. You said you have switched fuses, but I reckon you are talking about the external fuse and not the internal one.
Turn the amp upside down, remove all the Allen-head bolts (make sure you have an Allen key that fits exactly - it's not a common size) then examine the fuse on the circuit board. It's a very fine guage (2A from memory) and it's hard to see if it's blown or not. Take it out and test it with a multimeter is the best way to be sure. If it's blown, fit a new fuse.
I had a similar problem with my 2.1s that did very much what you described. It would start the power on sequence and then stop.
In my case, there was an issue with the tube socket fingers for one of the 6C33C tubes - it was on the "wrong" side of the pin (was not straddling it). I had had the amps for over a year and had just put in a new set of valves. Once I figured out what the problem was, I could manipulate the little fingers with needle-nosed pliers so it was on the correct sides of the pin. I imagine it had been like this since new but had not been a problem for the original owner. Fixed it permanently.
Regards,
Geoff
My mistake in assuming you meant Lamm ML2.2s when you wrote "LAMM 2.2's with the great NOS tubes".
I checked your profile and see that you have Lamm M2.2 monos. Please disregard my advice as it was for the Lamm SETs. There could easily be a second fuse on the circuit board however - but I have no experience. The specs on the Lamm site say:
AC voltage fuses:
8 Amps slo-blo for 100/120 Volts (4 Amps slo-blo for 220/230/240 Volts);
0.125 Amps slo-blo for 100/120/220/230/240 Volts, internally mounted. <<<<<
On the ML2.2s
Fuses:
4 Amps slo-blo for 100/120 volts;
2 Amps slo-blo for 220/230/240 Volts;
1.25 Amps fast-acting plate fuse for the output tube (V2);
0.125 Amp slo-blo for on/off and remote control circuitry, internally mounted.
Regards,
Geoff
AC voltage fuses:
On the ML2.2s
Fuses:
Regards,
Geoff
Thank you Geoff for chiming in. I did fine the second fuse...let's hope that that's the issue!
Good luck, Jeff.
Bob Hovland or Gary Garfield @ Musical Fidelity repair in Culver City might be able to help as well. Both have done stuff for me over the years.
Thanks Keith. We'll schedule that listening session once I'm back up to speed!
There's George Meyer on Jefferson.
They repair a lot of high end brands. They don't specifically have LAM listed, but they may be worth a call.
I just got my amp back from George Meyer audio in Los Angeles. Absolutely fabulous service, highly recommended for any highend repairs in LA.
