Kemp Elektroniks MaxiiMus P16
18,697
16,424
3,530
I discovered the seemingly wackiest, most woo-woo audio tweak I have ever encountered.
Please note the special crystal power source to handle the Tachyon field.
From the Kemp Elektroniks website:
MAXiiMUS P16
Maximization of natural energy
The MAXiiMUS derives its energy from the permanent flow of electrons from nature. This flow of electrons is caused by the difference in potential between the ionosphere and the earth. The strong Tachyon field in the accumulators inside the MAXiiMUS acts as an antenna which derives electrons from this potential difference and injects them directly into the circuit. This process enhances the efficiency of the electricity, which in turn leads to less power consumption. Audio/video sets will significantly benefit from this process too!
Single phase parallel unit
Plug&Play, no additional costs for installing
Raises efficiency of electricity
Optimises natural energy in homes and buildings
Harmonises low frequeny and high frequency elektrosmog
Repolarises underground water lines and other geopathic disturbances
Very long service life, doesn't need any maintenance
Environmentally friendly - energy consumption near zero
Wall mounting as a standard, foot for vertical erection supplied
Size of energy field created: approximate 13 m / 43 ft.Length of power cord 1.5 m / 5 ft.
Color white (RAL 9016)
Weight 4.7 kg / 10 lbs.
Sizes 32.3x18.8x6.2 cm / 12.7x7.4x2.4" (without bottom plate)
I bet you haven't heard for yourself what these can do?
I have one and like it so much that a 2nd is on order.
I must say I had hoped the "measurement" crowd would have learnt by now. I'm bloody sick of the continual armchair criticism
I wrote "seemingly" based solely on the text of the product information, but I have never compared the sound of a stereo system with and without a P16 plugged in.
I am glad you have one!
What are your impressions of the device, Whatmore?
Please tell us how the device changes what you hear from your system.
What do you believe the glass crystal does in the design?
I don't see any "measurement" crowd criticism above, just some criticism of "them" which you added.
If the hypothetical Tachyon Field can be manipulated via (what looks like) bubble wrap and a copper rod, I'm sure the "measurement" crowd would be all ears.
"Wackiest" "most woo woo".
No criticism?
My a'phile friends just measured one of these on the Audio Mephisto scope...capable of measuring any voltage down to .000000000000000001 volts. We saw a major upswing when connected to the Kemp...on the order of .00000000000012 volts!
:rolleyes::rolleyes::D
Reactions: cjfrbw
I have no idea who belongs to which crowd here.
I just read poo-pooing of a product that hasn't been heard and assumed that sort of behaviour comes from the measurement crowd.
I questioned only the marketing description.
So, again, what are your impressions of the device, Whatmore?
Interesting product alright---reminds of the Brock Polariser for the Holden Car in a way--well it did spring to mind --or a super Hi Powered multiple array AR-888 possibly
indeed awaiting the reports on your observations sonically and musically--cool!:b
BruceD
Very interested also for someone who listened it in his system. I read the Kemp website but can't understand the difference between the 3 different models.
Is the bigger the better wounding or just the more effective with well being ? Is the bigger model for big rooms ?
What if you install a big P40 or M100 in a little room ? Does it overload it ?
JY
BruceD
I have now found P16s hiding at the back of the main listening room of two audio salons in the last two weeks.
So it seems that professionals appreciate it ? As you can guess I like tweaking... good tweaks can help to extract the best from our systems. At least that's what I believe.
The 2 tweaks that light my interest now are Fostac and Bybee ARNs. Not much feedback from users (real men using them in their system everydays) on these 2 babies.
It would be nice to know what it is, unless it is indeed fairy dust.
My speculations on what it is would show a potential that it can do as much harm as good, varying by equipment used. But I think Ron is right to question them. I'm not sure there's anything at all that isn't utter nonsense in their marketing. The products might work but they don't work in any relation to the silly lies the entire website has all over it.
There's plenty of other manufacturers that aren't telling bold lies, offering good products that will accomplish the same thing.
Me and a bunch of others in 'straya tried bybees and the results ranged from "no difference at all" to "slight degradation". Don't think anyone reported an improvement or if they did, it was minimal
Hello
I asked Mr Kemp for explaining the differences between the 3 Maxiimus models. I paste his answer here :
The P16 is an easy to install shunt version, but if you have the room in your meter cupboard or near your A/V setup than the P40 or even M100 is highly recommended. The M100 is a stronger version of the P40".
