I'm still making changes but have it sort of figured out (Back in the Saddle Again - Kind of).
Moved after 27 years into a little house on the river (built 1947) with a finished walk-out basement, concrete floor at last.
After watching several Dennis Foley (Acoustic Fields) and many other videos plus reading articles including an excellent What's Best 2011 thread that explained how the subwoofer crossover can phase shift the polarity I have finally achieved integration.
Lots of cleaning up to do, as you can see in the photos below boxes everywhere, including my CD collection, Home Theater yet to be installed, and final room build-out just a dream on paper.
Old system.
My current 2-channel system:
Turntable: Dual 503 CS
Modifications include added dampening mass with plumbers seal in plinth and underside of platter, aluminum and acrylic plates below, output wires have been cut and terminated with RCA jacks, connected to preamp with 2 meter run of Cardas neutral Reference.
Cartridge: Grado Sonada, MM
CD Player: McIntosh MCD7009
CD Changer: 5-Disc Yamaha CDC-605
Tuner: Kenwood KT-5300 silver face ($10 from the recycle store).
Compact Cassette Deck: Yamaha KX-200U
Pre-Amp: GRAAF WFB One, tube with tube phono section (Italy)
AMP: Rotel RB-870BX (100 watts) solid state.
Future Amp(s): 2 Golden Tube Audio SE-100 (100 watts) bridgeable to mono with Russian Tung-Sol EL-34 tubes, awaiting restoration. They will go on spiked butcher-block platforms along front wall.
Speakers: Martin Logan - Aerius (the original 1992 - a pair of the first couple hundred built).
Subwoofer: M&K MX-80 push-pull 12" woofers, 80 watts.
Power Strip: Furman rack mount type with LED lights
Interconnects and speaker wires: Nordost – Blue Heaven all around plus some AudioQuest here and there.
Audio Rack: Atlantis (Canadian made)
Listening Chair: Eames lounge chair with ottoman (Chinese knock-off)
Record Cleaner: Record Doctor from AA, plus all the usual gadgets/guns/brushes etc...
Music: Jazz, Alternative/Progressive and Classic Rock…….and just about anything else.
Room: Approx. 11'W x 22'L x 7'H with plans to isolate (new walls/doors) and shorten to 15'L, close to golden ratio.
EDIT-1:
Future build-out will include moving stereo and H.T. equipment into built-in shelves under the stairs to the left after removal of closet wing wall.
A rectangular perimeter ceiling drop will conceal the last few stair stringer runs, and also serve as a bass trap + serve as duct run on right side.
Duct-work and many twists/turns with switchbacks to prevent sound migration into adjacent spaces and upper level will be incorporated.
Have considered a mini-split just for this room per Bobby Owsinski's video , but with such a small room I don't think I will need it.
https://ledgernote.com/reviews/best-studio-subwoofers/
Old system.
EDIT-1:
