Hi All... I'm using a Innuos Zen-Mini w/LPS and it sounds really good thus far! My Zen is feeding two DAC's I'm evaluating (1) PS-Audio Direct Stream and my just delivered Holo May KTE. My question is I'm feeding the DAC's via USB out of the Zen but my DAC's show the bit rate of only 44.1k whether I stream Tidal MQA or FLAC. I have found that there is a setting in the Zen that shows the following of which I am currently using "Native DSD". Which should I be using?
The Holo Day shows that it services the following resolutions via USB input:
- PCM 44.1-1.536M @32bit
- DSD 64-512X @ DOP
- DSD 64-1024X @native
