Is there anything you do? Or in the end, is it just about spending more money on gear that does a better job of bringing out your realism triggers so you can ignore it?
I agree with all the above posters. My vinyl is very quiet...but takes work...the right equipment, very clean records...it's just not a issue for me. I love the way my vinyl sounds. And I love my digital...
Do people use similar methods of disbelief suspension to listen through digital harshness and glare?
The Gruv-Glide spray (onto a micro-fiber pad and then treated) is indeed very effective.
Gruv-Glide is also effective at removing some detail from the sound as well. I've used it before and do not recommend it. I do not want that stuff on my stylus personally.
Feel the same way. When I got back into vinyl in 2010 with my first TT and before I had a real record cleaner other than a spin clean, I used it for a couple months on some records before recognizing it was better not to use it. If I have a record that would require gruv glide to make the record listenable, I get a better copy of said record.
I would really like to know (facts, not opinion) how it removes some details as that's not been my experience at all. I use it only on some LPs (very few in fact), so I'm not concerned about any stuff that attaches itself to the stylus.Gruv-Glide is also effective at removing some detail from the sound as well. I've used it before and do not recommend it. I do not want that stuff on my stylus personally.
I used it more when I only had my Spin-Clean, so I agree. How did you recognize it was better not to use it? I don't play records that are unlistenable, but I use the Gruv-Glide when I feel a copy could use some additional help after a cleaning with the NG.Feel the same way. When I got back into vinyl in 2010 with my first TT and before I had a real record cleaner other than a spin clean, I used it for a couple months on some records before recognizing it was better not to use it. If I have a record that would require gruv glide to make the record listenable, I get a better copy of said record.
That's going to depend on the record. In the example I posted above, good luck finding an ultra clean copy. Same thing goes for a lot of jazz LP's from the day.
BTW, IF Gruv Glide is removing detail, I would like to know how it is doing that....doesn't make any sense. Unless you have incorrectly applied the stuff, I also see no way how it is going to attach to the stylus.
Never thought of that....it's a valid point! I don't need the study now!Sorry Johnny, I don't believe any one has done a scientific study on the subject. If someone wants to fund one I would be happy to do it.
My choice of wording was poor. It does not remove detail. It obscures it, and it can be cleaned off the record.
If you clean your stylus with a fluid cleaner then it should remove the residue of the GRUV-GLIDE.
