Help installing Nagaoka MP-110 on Rega Planar 1
rogerrrr
8
31
Hi,
I'm new to vinyl and hifi, and have recently bought the Rega Planar 1, I want to upgrade the Rega Carbon Cartridge to the Nagaoka MP-110, and have one question with installing the Nagaoka MP-110.
I've researched on how to install it properly and have come across two ways of installing it:
1) From the Youtube video,
HiViNyws channel explains you have to change the VTA Position to 27mm, and no need to add a 2mm spacer.
2) From this other Youtube video,
Vinyl Explorer explains you have to add a 2mm spacer on the tonearm but do not adjust the VTA Position
I was wondering which one will be the better option or will both of these options lead to the same results or will doing both have a better sound?
I already know I have to adjust the counterweight with a stylus pressure gauge
Any help is appreciated, thank you
I was under the impression spacers under the tonearm is the only way you adjust vta on the Rega...
Reactions: jeff1225
