Goldmund Satya Installation - Fresno, CA
Rhapsody
3,668
7,261
2,635
Brooklyn NY
rhapsody.audio
Incredible system, but those speakers belong in the "Transformers" movies.;)
No, no, no, the Satya are babies.....we use these for "Transformer movies"1424503_1588250321496126_2959689844355773822_n.jpg
Now these look to fit in the space really well. How do they sound? Is that a wifi transmitter in the back?
Cheers
Cheers
Hi Bill, it's actually a receiver in the back of each speaker. The transmitter is at the preamp end. Each speaker has three dac's and three amps (one set for each driver) in it. You can run a digital cable from a Goldmund digital preamp/processor or you can connect from the dig preamp wirelessly. It sounds exactly the same wirelessly as wired, other than there is a limit of 24/48 when running wirelessly, 24/96 when running wired.
They sound delicious.
