Genesis V Manual
sheepdog1969
6
I am the proud owner of a pair of Genesis V speakers with the massive power amplifier. I bought them use and they did not come with an owners manual. I have been searching for someone who has one that I can get a copy from. Any help would be greatly appreciated. Thxs.
Thanks for the quick responses. I have read the "quick setup" instructions. I assume that when the unit was originally sold, there was also a more detailed explanation of how to use the remote tp set the various crossovers, etc. in the amplifier. Almost everything electronic today has a "dumbed down" get started instruction sheet and then a more detailed manual. Am I wrong on these speakers?
Having owned The genesis V, that was the instructions that came with it
I agree the remote can be a bit cryptic
Make sure the neutrik connectors are functioning
This is a servo unit, and there were issues with it not responding,
Andrew
awsmone-
You are the first person that I have made contact with that actually owned this system. My servo amp system is working, but I have not info on how to use the remote to adjust it or what all the abreviations on the buttons stand for. My internet searches have netted nothing. Are you saying there were no instructions with the servo amp? If so, how did you work your way through it to achieve maximum performance? Thxs.
if i have time i will double check if i still have the manuals
can u send me a photo of the remote
and i will see if i can talk u through it
great speakers, try valves on top!
somewhere i think i have a spare mid driver and tweeter lol
cannot find my copy just had a good look
found copy of hp review in TAS
The remote control is used to turn on, and set up the volume, and other parameters on the woofertowers. The display on the amplifier will alwaysflash to identify the function being adjusted.The high-pass "HP" filter determines how low thewoofers will play. Set this initially to 16Hz. Then,adjust the low-pass "LP" filter (how high afrequency that the woofer plays). Set this to100Hz using the buttons marked "LP". Use thebutton marked "VOL" to adjust the bass gain to15, to start with.If you are using the Servo-Bass Interconnect, use the "PHS" buttonsto adjust the phase to 0 (zero). If you are using the output from the preamplifier to drive your Servo-Controlled Bass amplifier, and yourpower amplifier is a solid-state design, adjust the phase to 45. If yourpower amplifier is a transformer-coupled valve design, adjust thephase to 75.The remote control has two buttons on the lower portion of the hand-held marked "MEM 1" and "MEM 2". These controls will memorize thesettings you have selected. To memorize a setting, point the remotecontrol at the amplifier. Press the MEM1 or MEM2 button and holddown for 2 seconds. After 2 seconds, the reading will flash and yournew settings will have been memorized.To recall the memorized setting, press the appropriate memory buttononce. You may want to memorize two different settings to match yourrecording's bass level closely, or you may want to use one basssetting for music and yet another for video.1.7 Crossover ControlsYou will notice two control knobs on the crossover box. The left handknob is a volume control for the rear tweeters. Turning this controlclockwise will increase the level of the rear tweeters. Use this control ifbityou need asoundstage. Start with this control at the twelve o'clock (high noon)position.The control on the right side is a five-position switch used to adjust thesoundstage height. Depending on your room acoustics and youramplifier, position three has the sound stage at about the middle – likethe soundstage when you are seated in the stalls seats in a concerthall. Position five pushes the soundstage high, like the orchestra levelseats, and position one has the lowest soundstage – like you are inthe circle seats.2 Tuning the systemMusic is the best way to begin your setup procedure. We suggest thatvideo sources be used only after you have setup the system toproperly reproduce music.We suggest that you start with a single female vocal with instrumentalaccompaniment because the sound of the human voice is more easilyrecognizable than many instruments and is the least complex sound
Thanks so much for the "walk through". I'll get my hands dirty and see if I need any specific help. Since the settings have to be changed while the amp is powered up, I assume one could change a setting while listening to a song so the system tuning would be real time. Yes?
Yes, don't forget to save settings to memory !
Please let me know how u get on
I was just thinking...the bass modules r capable of prodigious bass, i remember my window panes flapping when i didn't adjust them properly so be aware that infra low bass is possible and u may not hear it, and will muddy your sound
I have found when adjusting deep bass either start with it low volume and adjust up till it just suddenly seems to have the sound stage float or start to high and wind down till it suddenly disappears i.e. that effect, if you haven't experienced that effect before I suggest you start too high and wind down, you will notice it as soon as it disappears
the other comment I would make, is don't put these speakers too far apart, they couple very well, and are one speaker that produces images outside of themselves with great recordings
Aim straight forward not toed in at all
They can actually work very well quite close to each other
They are capable of an enormous soundstage
Good luck
andrew
