Genesis Remote Control Codes
carolkoh
920
240
1,605
Seattle, WA
www.genesisloudspeakers.com
For those with old Genesis products such as the Digital Lens, the Stealth Amp and Amps for the 200 & 300 series, we have loaded the codes to Logitech's database. Search for brand "Genesis" and product "Amplifier" There is only one model.
Otherwise, if you prefer to program a remote control yourself or use a different brand of programmable remote control, here are the Hex codes for everything.
If you have a current model and want to consolidate all your remote codes into one, use the "Sub" codes.
  • Remote Codes.pdf
