Genesis 800 watt servo amp
sheepdog1969
6
I have a fully functioning set of Genesis V speakers with the 800 watt servo amp with remote. I can not find any info on how to use the remote and adjust the settings in the servo amp. My internet searches have netted "zilch". There must have been a set of instructions that came with the servo amp and remote when they were new. Help!
Hi Sheepdog1969,
Have you downloaded the manual? You can find it here in PDF format : http://www.genesisloudspeakers.com/archeology/genv_vi/g_v_manual.pdf
*EDIT* I see that you have (posted in other thread)
What exactly are you looking to do / not understanding?
If you download this - http://www.genesisloudspeakers.com/archive/G201_Owners_Manual.pdf Check page 7
There's basically only 3 adjustments - Volume, Phase & Hi-pass/Lo-pass - ignore all the other buttons on the remote control. The same remote was used for the Digital Lens as well.
Hi Carolkoh,
The second download is "EXACTLY" what I was looking for! At this point, the only additional question I have is the "Mem1 & Mem2" buttons. My assumption is that they allow one to save 2 setups (set volume, phase & hi-pass/lo-pass--press mem1, then readjust for a different genre of music and press mem2). Am I correct? Thxs in advance for your help!!!
