Do we really need to understand this?
DaveyF
6,129
194
458
La Jolla, Calif USA
Do we really need to understand this.OR, do we really need to accept this??
On the A'gon site, we have a vendor selling a Synergistic Research receptacle...which has been "tesla'ed"
The copy reads: The Synergistic Research TESLA Plex SE is a Quantum Tunneled duplex outlet.
Quantum Tunneling is a process that changes the way a conductor works at the sub atomic level, impacting the entire TESLA Plex SE assembly. By applying a two million volt signal to each individual unit, at a specific pulse modulation and an ultra high frequency, for an exact duration of time, transforming the outlet at the molecular level. This process is also performed on all cables, from the Core series to the Galileo series. The “before and after” is startling, with a lower noise floor and improvements in inner detail, air, low frequency extension, and overall transparency.
So, the question is do we really need this kind of "science" in our hobby and more appropriately does anyone 'understand' this. Or, is it that an ad likes this gives an 'impression' to the non-a'phile that IMHO we can certainly do without in the hobby. Your thoughts----
As far as I know, quantum tunneling has nothing to do with a two million volt signal. The guys is just trying to screw us with pseudo-scientific language. I am sure he doesn't even know what quantum tunneling means.
We don't need this bullcr**, and yes, it gives a silly impression of our industry.
I'll happily live without a quantum tunnelled receptacle herewith and forever.
Gee, whats next from Synergistic? Maybe alien technology? I hear that the aliens have super sound systems! Maybe they can do things at the quantum level if they can master interstellar travel. Synergistic Research, not so much.
Better not tell that to Ted Denney! Oh, I forgot he is one of them, LOL.
There is an old saying.."A fool and his money are soon parted." LOL.
Happy Halloween!!
I have no idea whether that makes any sense or not. However, since current flows at the atomic level it would seem possible to be able to optimize it at the atomic level. Whether the technology exists yet to do that type of manipulation is unknown to me. I have seen photos where IBM arranged atoms to spell IBM, but I don't know if that can apply to making better sounding cables.
If you want it, here it is, come and get it
Make your mind up fast
If you want it, anytime, I can give it
But you better hurry 'cause it may not last
Did I hear you say
That there must be a catch?
Will you walk away
From a fool and his money?
But you better hurry 'cause it's goin' fast
Did I hear you say
Will you walk away
Sonny, if you want it, here it is, come and get it
But you'd better hurry 'cause it's going fast
You'd better hurry 'cause it's going fast
Fool and his money, Sonny
But you'd better hurry 'cause it's goin' fast
You'd better hurry 'cause it's goin' fast
I wrote this for my "blog" page on ComputerAudiophile.com a while ago, but if you permit me to cut and paste, ...
By applying a two million volt signal to a cable at a specific pulse modulation, and ultra high frequency for an exact duration of time, we transform the entire cable at a molecular level through a phenomenon called Quantum Tunneling. This process is performed on all TESLA Series cables, from Galileo Basik Strings and Au 79 and Magnetic Tricon to Apex, and can be applied to models not Quantum Tunneled for an additional charge. The before and after is startling, with a lower noise floor and improvements in inner detail, air, low frequency extension, and overall transparency and signal speed.
http://www.synergisticresearch.com/tesla-series/tesla-series-technologies/
So, you might ask yourself, what is quantum-mechanical tunneling?
When I teach this (as I do, every year), I sometimes make reference to a more familiar phenomenon. If you take a laser beam, and point it at a glass prism, what you will find is that part of the beam is transmitted in the original direction, and part is split off, and reflected. If you change the angle of the prism relative to the incoming laser, there comes an angle, called the critical angle, beyond which all the light is reflected, and none is transmitted. It looks like this:
Now take a second prism, and place it next to the first one. If the two glass surfaces touch, suddenly you get the laser beam propagating out in the un-bent, transmission angle again.
That's the optical version of tunneling.
You can treat this classically, using something called an evanescent wave. You can also treat it quantum-mechanically, and it is again the same sort of wave phenomenon, except the wave now describes the probability of finding the particle in what we call a classically forbidden region. So it works exactly the same way for photons and electrons. The electron "tunnels" through a barrier despite not having enough energy to hop over it.
It doesn't change the molecular structure of anything. Not the glass. Not the wire. Nada.
These guys might be doing something else to "change the molecular structure" of the wire (which, by the way, isn't made of "molecules" in the first place, but rather an array of metal atoms). But it ain't quantum tunneling.
Hi
WGS thanks so very much for explaining the phenomenon... I will read and re-read it ...
Thanks also Hi-Fi Guy for your charming poem (?) :)
The sad thing is that several here and elsewhere when confronted by this item which does the tunnelling (sorry WGS :() will suddenly hear the "vast" improvement brought to their system when they use it.. They will also hear the "night and day" differences and the ensuing "collapse of the soundstage" once they use a different outlet. Of course once used, the music will emerge from a ' much darker" background and dynamics will be increased as well as "rhythm and pace'. Let's not forget the obvious increase in PRAT those produce ... We wilt not mention the smoother midrange and the more tuneful bass
PT Barnum would have made so much more had there been audiophiles in his time ...
Hi
Yes, thanks guys.
I would not be surprised if some of my fellow audiophiles who heard such "drastic" differences under suboptimal show conditions at the event that I describe here might also fall for that:
http://www.whatsbestforum.com/showt...-and-Listening&p=348580&viewfull=1#post348580
In any case, how much does that joke even cost?
Hi
No problem, anything to help out.
https://youtu.be/Jkkcs5JMiPs
The technology does exist, and it can produce a wire made of a continuous crystal of atoms with no grain boundaries at all, it is the Ohno Continuous Casting process, or OCC. Currently, Wan Lung Electric (Neotech) is the only company licensing this process and they do make the best wire for audio use available today.
A couple of more: wider and deeper soundstage, much better granularity of subtle background cues, better image specificity, and (lest we forget) improved gesthalt.
Oh, so for a hypothetical - and unrealistically high - outlet resistance of 1ohm, they are putting through 2 million amperes through it; or for a more realistic 0.1ohms, about 20 million. Assuming they can get that power into the facility, welding and melting occurs at much lower amperages.
Raising the distinct possibility that the explanation isn't the only thing they just made up.
For electricity to travel 1/4 of an inch to get from standard Romex copper wire to your power cable
I once had probably 2 million volts applied to my audio cables. A direct lightning strike to a metal fence that was inches from the electrical service entrance. The treatment was therefore applied to my romex cable, my power cords, power outlets and all audio equipment. I must say there was an eerily black lower level of noise afterwards.
Maybe I should move to Florida, string cables in the air waiting for lightning storms and sale the struck cable as all natural cables treated by God's own hand. Surely it would sound like heaven itself.
Maybe i should move to florida, string cables in the air waiting for lightning storms and sale the struck cable as all natural cables treated by god's own hand. Surely it would sound like heaven itself.
ROFL! Sorry to hear about your lightning strike.
