I remember reading this from HP a while back. Is this (or was this) true or is he just creating something out of thin air?
ive heard the Martin logan CLS sound 'plasticky' same with esl-63s ive owned. never heard those colorations with my ESL-57s or Soundlab A-3s when i owned those. in hindsight it was probably the sound of overdriven panels w/ low freq. resulting in the diaphram slapping the stators - just a theory. not being stats, ive owned maggies and apogee duettas that had similar colorations. i dont have the balls to over drive my 57's as i love them too much. i remember 250 krell-watts per side couldnt peak the A-3.
That sounds to me more that the amp hasn't got the grunt to deliver the sound to the speaker, rather than the speaker itself. The older electrostatics are a pretty vicious load to an amp, and the power supplies in ones not up to it collapse under the stress of trying to do the job. Hook up a Krell with sufficient meat, and in good condition, and I'd bet there wouldn't be any problems ...Sometimes, when you come across a speaker that cannot handle the powerful strike, the depth of the note and deliver the fullness of the note, the strike ends up sounding shallow, and the deep powerful strike peters out too quickly and the note itself no longer seems to resonate in a heavy wood, and metail cabinet but (you guessed it) a plastic or flimsy one.
Frank
The bizarre thing, that most people don't realise, is that a single, high level, continuous note is much more stressful on an amp, in fact everything, than a very busy mix, that sounds very loud. You know the warnings on test CDs that send a single frequency at full volume, or close to it, through your system, they mean it for very good reasons! An opera singer hitting a high note and sustaining it is vastly more difficult to render than a heavy metal track thrashing itself to death. So, a system may do excellent soundstage, etc, but give it one solitary, maximum volume note and it will go bye byes ...Yes but if the amplifier wasn't up to the task, the first thing one would probably hear, esp. back then, would be a loss of dynamics and soundstage. And yes speakers like the Dayton-Wrights needed an arc welder to drive them.
I rest my case ...I think it is intrinsic to the mylar film and can be much exacerbated by incompatible equipment or room acoustics. Under normal conditions, with the proper setup it is almost inaudible. Some recordings can help to show it. "Friday night in San Francisco" is a terrible test for it, as it shows clearly in plucked strings.
Frank
I think HP was referring to early Accoustats when talking about that plastic coloration. Thing is HP doesn't know the cause of the coloration eg. is it the diaphram, transformer, parts, etc.
Years ago he talked about the Magnepan sound; yes it existed but it wasn't caused by what he thought. Actually it was due to the parts selection in the Magnepan at that time eg. polyester caps (not to mention those hideous ferromagnetic leads that serve no purpose other than allowing the cap to be automatically picked up off the assembly line), iron chokes, alpha wire, etc. Get rid of that and it was a different speaker altogether (esp with the ribbon).
IMO, plastic coloration with electrostats, paper coloration with paper drivers, metallic coloration with metal drivers, have more to do with the crossovers than it does with the drivers themselves. Of course, other speaker designers will have different opinions and will never use metal drivers for example. After the crossover, then the amplifiers make the second biggest difference. I have heard the most glorious choral reproduction from Martin Logans, for example. No plastic there!! But that takes megawatts.
