DDC Options
jerrybj
315
168
113
62
New Zealand
I'm looking to upgrade my Digital to Digital Converter.
Currently have an M2Tech HiFace Evo Two.
What are good choices up around $400-$650ish?
240v, with I2S out.
Possibles after a quick Google search
Denafrips Iris
Gustard U18
Topping U90
Any advice greatly appreciated.
...I recognize I will be outside your clearly stated budget @jerrybj but I use the Denefrips Gaia in a system here, and it has worked well, build is good, etc. In addition, I found Alvin Chee at Vinshine to be solid to deal with and very helpful. Hope that helps, at least a bit. Good Luck!
Reactions: jerrybj
240v, with I2S out.
Denafrips Iris
Gustard U18
Try Singxer SU-6
