What are your thoughts on the comparative fidelity of different radio carriers:
1. Internet
2. Satellite
3. Over the Air
lee
In general, #1 is the winner although in the specific, it might not be there. Let's examine them:
1. Internet. Audio is compressed using a popular compression format like MP3 or WMA/AAC. The key there is the data rate. If 128 Kbps (or 96 for WMA/AAC), it can sound better than the other alternatives. I have not done a survey but seems like there are a number of internet radios using 128kbps. Key here is that no bandwidth is taken up for error correction as the channel is pretty reliable relative to over the air schemes below.
2. Satellite. XM radio uses PAC and Sirrius HE/AAC. The latter is much better than the former but it is still a way of cramming a lot of audio bandwidth in low data rate channel. Specifically, techniques are used to recreate high-frequencies in HE/AAC that were filtered out of the source. Data rates are quite low due to dire need to have lots of (forward) error correction to deal with weak and noisy RF signals. Typical audio rates are 32 to 64kbps. I find the audio quality extremely poor for XM and unlistenable.
3. Over the air. As you know, we have both analog and digital versions of the same. Analog FM is band limited to 15 KHz and suffers from very poor scheme for transmitting the difference signal needed to create stereo. Multi-path distortion where the receiver sees the original plus delayed versions reflected from other objects can cause lots of fidelity issues (although there are good implementations out there to get around this problem for the most part).
Digital Audio Broadcasting (DAB) as used in HD Radio in US can be reasonably good. Broadcasters are allowed to go as high as 96 Kbps although many are using 48 Kbps. Lots of extra channel capacity is taken up by forward error correction. While I readily hear compression artifacts on HD radio, it is much less than XM and in most cases, better than analog FM in my car. The stereo image is much better as is the frequency response. Compression artifacts are there in the form of lisping, and some amount of pre-echo and modulation (underwater sound). HD radio also uses spectral band replication as explained for Sirius.
So in my book, internet streaming done at high data rate easily wins out. At high enough data rate of say, 256 Kbps, it can rival CD for non-golden ear listening
