Balanced (XLR) "Y" Cable
msm_1
42
2
Hi
Having a pair of DMA 200's and only 1 balanced output, is there a cable that will split the single output into 2...and....if possible, will this be harmful or diminish the overall performance?
Any idea's ?
Thanks
Mike
Any cable company can make a Y cable. Not ideal but worked for me and it seemed to sound OK. I used Audioquest at the time
No problem with splitting it. Any half decent music shop should have the parts or you can buy them online: http://www.bhphotovideo.com/c/product/434617-REG/Kino_Flo_PWC_X42_Splitter_Cable_1.html
The output will drop some but should not be a cause for concern at "macro level."
Hi msm_1 - what are you trying to do exactly?
Hi
I have 3 Pre's at this time, a Rogue 99 ( has 2 rca outputs but no balanced ) a Rogue 66 ( same as 99 ) and a Classe DR-6 ( has 1 balanced output )
I want to hook up both my Spectral DMA200's using the balanced outputs ( Several people have said that the DMA200's sound best by using the balanced hookups ) and not the RCA's
Thanks
Mike
So if I understand you correctly, you want to simultaneously plug in as many preamps as possible to the amps, and your way of doing it is with Y cables??? If that's the case, this is a major no-no with any amp... Or am I missing something?
No,
I want to use only one Pre and 2 amps. The Classe Pre, has only one balanced output so I'm trying to figure out if it's posible to split the one output without harming any of my equipment.
My other 2 Rogue Pre's are tubed, but have only RCA's for hookups and will not be in this system
Thanks
Mike
That's a safe configuration. Once you get it working, do a test. As one configuration is playing, disconnect the cable from the other amp and see if you hear an audible difference. If not, you are good to go.
Thanks, I am looking into whether the Rogue's can be modded with 2 balanced outputs, instead of the existing 2 RCA's outputs
Thanks again
Mike
Hi msm_1,
I use the splitter that amirm posted to feed the signal from the preamp simultaneously to the main amplifer(s) and the subwoofers. The sound is just fine and dandy for me. I don't feel that the sonics have been diminished in any way.
Hi
Sorry for bringing up this older post, but I have'nt had time to work on my system till now.
I have one quick question..... If I'm using all spectral or MIT cables, yet need a Y splitter to go between my SDR and my pair of DMA 200's. Doesn't this take away the use of the MIT cables as the Y splitter won't have the full bandwidth capabilites that the MIT's do?
So, to the point, the cables are not a real important factor as the performance and sound will only be as good as the quality of the splitter?
Just trying to figure out, as there are some big differences in pricing MIT cables
Thanks
MiKE
Hi msm_1,
I use balanced splitter cobbled up using Gotham interconnects. I don't feel that there is any degradation as it is just a short run of less than 6 inches.
When I used the Y splitter before, I also did not feel any degradation. I look at the Y splitter as just an extended part of the RCA jack.
I have done this using different MIT interconnects such as 330E, shotgun, CVT, Oracles and it worked fine in every case. I suppose going through the Spectral RCA jacks and through splitters do not make much of a difference as Spectral's internal wiring and jacks are pretty standard.
If you wish to really experiment, you can bypass the SDR's RCA jacks and solder your interconnects directly to the SDR's board.
I have changed the internal wiring of one of my Spectral DMC 20 preamps from the input RCA jacks into the board and from the board to the output RCA jacks; at the same time, I changed the RCA jacks to Cardas brands and there was real improvement with these tweaks. Be warned though that this voids the warranty.
Sam
Hi Mike,
Nice to see you over here. have you tried bi-amping with the single ended outputs first? I mean if the mids/treble amp and the bass amps don't match up, at least you'll know without spending a dime. Anyhow I've heard Mullard's Y-cable set up and I heard no degredation. Then again the application is a bit different. He's got one pair of xlrs going into amps for his monitors and the other into his Element powered subs that start work pretty low.
Anyhow, good luck!
Jack
