Ayon amplifiers
morricab
10,675
6,109
1,958
Switzerland
Hi All,
What are your impressions on Ayon Amplifiers? Specifically the SETs based on the 62B and 82B triodes?
Cheers
I believe user Marslo has one. PM him.
Hi All,
Cheers
Yes, I have a Crossfire amp. 30 watts of single-ended power. I have used it with several speakers with excellent results: Devore 0/96, Vivid G4, and Sound Kaos Wave 40. It has all the famed single-ended characteristics with a notable full and powerful bass response.
Hi All,
Cheers
I have Ayon Crossfire since 2010 when I changed my speakers from JM Lab Electra 1037 be to Duo Omega G2.
I owned all 3 iterations of Crossfire , IMO it's close to perfection match with AG speakers.
I tried many ss and valve designs and I am of the the opinion that AG sounds best with SET amplification.
Crossfire gives no typical valve sound - it's fast ,dynamic with holographic sound stage and very colorful bass.
The bass is of course a bit less controlled than with ss amps ( like XA series from AG ) but with much more colours and saturation. Compared to that, ss designs produce better controlled deep bass but it is washed to me.
And it has punch and power - plays louder than 100 -150 W ss designs, as loud as for example ARC ref 150 power amp , as far as I remember. Cons ? With efficient speakers it's always a little bit of hum , when you approach the ear to mid horn is audible. Here XA pre/power combo from AG has the edge.
Agree on all points. Every Ayon amplifier that I have heard was superb sonically. Probably my favorite tube amplifiers. I may get a set of the mono-blocks.
I am pleased you agree with my opinion, I am looking forward to hear about your impressions when you get monoblocks.
Would you get Crossfire Evo or rather Titan/Vulcan series?
rgds,
Mariusz
Have heard them quite a few times and they typically have very good setups. Always very natural sound and very quiet for SET's. One of my preferred amplifier brands in the SET category
