I have, and it's a great unit! Performs flawlessly, day in day out... Its only down side is USB-only digital outputs!
What do you want to know specifically about it?
this will be my first entry into computer/server music. would the music stored on the aurender or any server sound better or the same as playing cd on my oppo 105D? just wondering other than convenience and a new way of picking music would i be better off looking at a better cd player and DAC? thanks.
I don't have that product but have been using a music server for a very long time. I went that direction when the music server was blind compared to the dCS player and there was no contest (server won). My guess as to why: I have always thought digital's shortcoming was taking it from the source to the physical disc, not digital itself. The software my server uses to rip music does all kinds of error checking where as my Oppo has no chance to do that in real time. Whether that actually has anything do with why I think it sounds better I don't know. Add the sonics and convenience, and you will never go back.
If you rip your CDs properly, and play the files back through a proper server, there's no chance for the Oppo, who must read the disc in real time.
One thing, though: AFAIK, the Oppo has no USB DAC inputs, so you won't be able to use that particular Aurender model. My suggestion is to go with new standalone DAC paired to the Aurender.
Interesting debate. After not using my DCS transport for many months, last week I put it back into my Scarlatti system and compared SACD quality from disk with Flac 16/44 playback of ripped or Qobus streamed material using my Aurender s10. No contest! The disk player is being sold together with my remaining disks.
All I want now is for Aurender to continue their software updates to give me internet radio in the UK.
Very positive experience with the N100H. My music has been ripped to a Synology NAS and the playback with the Conductor app has been quite reliable. The scanning of the meta data works well now that I have an Apple.
Another factor not to overlook is support Aurender provides. Requests are initiated right in the Conductor app and response from Korea is prompt and good.
I find the sound to be on the warmer side of digital. Complimenting the N100H with components that don't sound "digital" results in a fantastic sounding system.
I realize the N100h is not their high end unit so I look forward to moving up the Aurender foodchain.
Another factor that might affect your results is selection of the USB converter if you need one. I've found the Berkeley, which I use to concern to AES, sounds best to me. Try a couple of them to figure which suits your ears best.
One issue that affected me was playing music from a USB stick using the Berkeley: it doesn't work reliably!! Somehow they don't communicate cleanly so when you push the play button it doesn't work!! After removing and reconnecting the USB cable from the N100h and the Berkeley did it sometimes work. Swap out the Berkeley with another converter and all worked fine. Quite frustrating having an expensive system that won't play music!! The good news is that if your music is loaded on the N100h or on a NAS this problem is eliminated.
Good luck!
Popspin
I agree with your assessment of the Aurender's character!
Reading your post, I thought you might want to investigate an Aurender N10 sooner rather than later, given that you're using a USB converter anyway, and the N10 will provide you with a clean(-er) digital output to your DAC (SPDIF via Coax or BNC), instead of converting USB in a separate box. It's not AES, so I don't know how that'll work with your DAC...
Hi Alex:
Yes!! I was heading in that direction but choose not to say that yet.
I totally agree and if I bought today I would get the N10!! Exactly for the reason you state. Add up the cost of the N100h, the Berkeley converter and a high quality USB cable and you end up so close to the cost of the N10 it almost becomes a no-brainer. Unfortunately I didn't quite see that when I purchased and my former dealer failed to advise me properly.
The N10 does eliminate the need for the USB cable and converter by providing an AES output (for others to understand, Alex) and provides improved sound quality along with more internal storage. The N10 is my next step as I watch what Aurender does to update the W20.
In the meantime I remain extremely happy listening to the N100h.
Popspin
could you explain what do you mean with "to rip properly"
I do it myself with my an Apple extern CD reader into MacBookPro SSD in AIFF ... right / wrong ?
Yes, AIFF is my format of choice. I use the XLD app to rip the CDs, instead of iTunes, and I recommend you do the same It can rip directly into iTunes, if you're still using it to catalog your stuff...
