I am curious if anyone here has tried or owns the ART1000X cartridge? I haven't seen much coverage other than a couple of reviews.
Bill,I am curious if anyone here has tried or owns the ART1000X cartridge? I haven't seen much coverage other than a couple of reviews.
Great Ron! Thank you for that information. How did you detect the zenith error? Send it to J.R.? Also, what is your impression of the tracking ability?Bill,
I have the ART1000X cartridge installed in my system for less than a week. I replaced an Ortofon a95 that had seen it's better days.
I would like to let you know that the first cartridge sent to me was defective due to a large (16%) zentith error, which I sent back to AT under warrantee. They sent it back to Japan to replace the stylus tip and cantilever. This took 4 months.
As for the sound, my initial impressions are positive. The sound is really vivid and fast like the Ortofon but with a bit more relaxed and for me, immersive. This is after 3 days of listening to mostly classical music so far and remembering the Ortofon after not having it in my system for 4+ months.
Hope this helps
Bill,Great Ron! Thank you for that information. How did you detect the zenith error? Send it to J.R.? Also, what is your impression of the tracking ability?
That is quite horrible quality control from AT, only few users will have the tools or take the effort to find a faulty manufacturing like this. Glad it worked out for you, but I cannot help myself thinking about what others might be playing with without knowing. My OC9 is 1 degree off Zenith.I would like to let you know that the first cartridge sent to me was defective due to a large (16%) zentith error, which I sent back to AT under warrantee. They sent it back to Japan to replace the stylus tip and cantilever. This took 4 months.
Very likely, there is a good percentage of cartridges whose zenith angles are off by more than 15% according to J.R. These folks have no idea that this is the case. Other than sending it to J.R. or having a really good microscope, and a lot of patience, one is at the mercy of the manufacturer. You are fortunate to have only a 1% zenith angle error. Probably just luck of the draw.That is quite horrible quality control from AT, only few users will have the tools or take the effort to find a faulty manufacturing like this. Glad it worked out for you, but I cannot help myself thinking about what others might be playing with without knowing. My OC9 is 1 degree off Zenith.
