Atlas SL arrived
gian60
2,598
2,115
578
I am very crazy for cartridges,since always,so yesterday visiting Italian distributor of Lyra,Audiograffiti
i saw one and i bought.
Yesterday Audiograffiti,that i know since 35 years, invited me for the presentation of new Spectral mono DMA 500 and Mr Fryer did presentation for Spectral 40 anniversary and very good food around 12.30
The system was
Spectral 4000 SV with preamp 30 SV and new amp DMA 500 with speaker Lansche 5.2 and top MIT cable
Sound was good but i always listen Spectral,also this little light on mid bass with voice with few body and little bright,but better than the old.
I listen many times Atlas from friends and i like because is very fast,open,dynamic with good bass and also deep and a lot of details,but i founded little less natural,or little electric than Opus and Coralstone.
I never listen SL but i read that sound is more natural than normal Atlas si i am curios to listen this in my system
Atlas reach Coralstone diamond,GFS,Opus 1,A 95,Audiotekne,Spu A 95,so in future when will arrive Torqueo with or Ikeda 407 or Saec 506 i will do test changing headshell easily
On Bergmann now is difficult to change cartridges for his litz of tonearm very very thin
I had 12 years ago Lyra Titan and Koetsu Jade Platinum.
Titan was fast and open but little electric sound and Koetsu was more natural but little dark and with mid bass little heavy.Italian distributor told me the new stone Koetsu made in the last years are different from models of 15 years ago,more modern sound
Regards
The number AS 025 is the serie number where AS means SL
Normal Atlas has AT and mono Atlas has AM
i saw one and bought ...
Congratulation Gian. Hope you change clothes more than carts :p. We are similar kind. The Atlas SL can be very "show off" at first. I can understand why Marc Gomez likes this cart on his arm...because it even further compliment the ability of his arm in digging out info from the groove. Give it some time and it will build more meat on the bone. Still skinny though. I like it a lot with strings.
I have Atlas SL, Coralstone, Anna, Opus, Palladian, Etna Mono coming, GFS gone and a ZYX when destiny strikes one day. It will take some time to learn them. After that I can send the one you dont have to you for testing. Will be fun.:D
Kind regards,
Tang
Reactions: Jamesdonahue
I think both Mike and Gian today in separate threads admitted to being crazy.
Hi Gian
Congrats on the Atlas SL. If it’s anything like the Etna SL it will be superb
Pradeep
Sawasdee Gian,
How is Atlas SL doing now?
Tang
I am listening Atlas SL since 5 minutes
with phono CH P1 in current with gain + 15 ( maximum is + 25 ) and volume on L1 is - 34 db,my speaker is 98 db
Very beautiful cartridge also this
Big scene,big separation between instrument,fast and dynamic,
high very detailed but sweet,bass correct and deep mid transparent,now little less natural than opus 1 on mid,but have only 5 minutes
Sorry my poor English
When you turn volume to -25db and dont play music, do you hear any hum coming from your speakers?
First impression after listening some of my reference record
High are incredible clear fast detailed and high go on until other cartridges stop before,really fantastic
Voice are very good because are open,natural,clear and big out of the speaker
The instruments seems real because are big and a lot of space between them
on classic guitar i listen very very little electric sound while in opus and coralstone seem more natural,but this very little electric sound i listen also in Atlas of my friend and more with my old Titan
Midbass is little light,so some records are ok,in other the sound is little light with few body,while opus is much better in mid bass that is full with the right body on male voice and instrument
For exemple in moonlight serenade with L Almeida and R. Brown,the double bass of R.Brown is perfect like the Opus 1 while in St. James Infirmary,45 rpm Classic Records, the voice of Armstrong is little light while with the Opus 1 has one body that the voice seems true in from of you
In La Campanella with Accardo at the Violin,Fone' 45 rpm,the violin is perfect and seems true,real,fast,while the double bass is little weak
The bass is good but opus has more deep bass and more punchBut we will see after 120 hours what will happen
GFS is some months i don't listen but seems a copy of this Atlas SL,but i will try in future
A 95 i listen very few hour,have to check after 100 hours at least,but is not in this category for me,
Coralstone Diamond has not the high of Atlas,has not the deep bass of Opus,has not the perfect mid bass of Opus,image is smaller that Atlas,but when you listen you enter in the music and enjoy without thinking at the hifi
Tang has Atlas sl on Kronos that is a TT with more mid bass than Bergmann with SAT that is heavy and could be perfect match with Atlas so could be the mid bass is perfect
So with 2/3 TT ,some different tonearm and phono cable you can find the right match to listen this cartridge in the perfect way.
Which is the best cartridge i have
I dont know
Now i put the weight at 1.72 gr instead 1.67 before and seems more better in mid bass
