Amp Stand for Dartzeel....
Tabl10s
207
122
148
63
Sacramento
what are you using?
Saw a Pic on A'gon with SRA/Dartzeel and thought I'd ask. Which do you recommend?
Select based on budget. The least expensive model (https://www.silentrunningaudio.com/isolation-stands/ohio-class-xl/) is absolutely a valid choice and sounds great; I show with it frequently. Often when discussing choices for a piece like darTZeel, budget allows the statement Virginia Class pieces (https://www.silentrunningaudio.com/isolation-stands/virginia-class/). They're exceptional.
615-838-7178 if you'd like to talk through options.
