Amanero now supporting native DSD In Linux
Swisstrips
28
11
235
Not sure if this is old/new news or applicable, but I know I am wanting native DSD for use with HQP / Lampi
http://www.amanero.com/drivers/nativeDSD.txt
To enable/disable native DSD on Combo384 an USB Control request must be sent to endpoint 0. This procedure is supported on all firmware versions.
On firmware_1099rc1 an USB alternate settings "2" with a native DSD endpoint is supported.
The control request is of type Vendor to the Device.
bmRequestType=0x40,
bRequest=0xB1,
wLength=sizeof( struct VAD_DATA ),
Data is a variable of type struct VAD_DATA
struct VAD_DATA {
unsigned int command;
unsigned int length;
unsigned int buffer[64];
To enable native DSD
command=0x8000
length=0
buffer=undefined values
To disable native DSD
command=0x10000
length=0
I should have stated in the title "DSD native with Linux"
Okay - I was wondering what you were on about in the first post :)
Yeah I kind of figured that after the fact, oops :) I know the Lampi crowd (me included) using HQP/NAA will be happy to hear this. I asked the admin to append "Linux" to the description.
Do you know a procedure on how to write the published commands in the firmware?
Nope sorry, just relaying what I found
