Aesthetix Io On Active Isolation Platform?
19,547
17,517
3,530
Has anyone experimented with placing an Aesthetix Io on an active isolation platform, such as a Herzan?
What differences did you hear with and without the active isolation platform?
What does Greg Baron have under all his IO eclipse boxes? Oh shun mooks
Don't Mook me! :)
I have Shakti Stones and woo-woo wood. And I route my cables according to Feng Shui.
An active Herzan must beat passive Mooks.
I'm going to be trying HRS nimbus footers under my IO Signature. I will follow your attempts greater isolation.
Don't Mook me! :)
Hi Ron,
Did you get the 3 box version installed yet? Also have you rolled any tubes? In terms of the question about active isolation, I would be very surprised if it didn't radically improve it. That said, you would need 3 platforms if you go full IO hog.
I guess active support is now going to move from solely the preserve of tts to other gear
What w all those Io tubes causing vibration, Herzan makes a lot of sense
I'm actually done w Mooks, I'm getting nowhere near the impvt in my new room as I did in my previous place
No, Bill; the house won't be repaired for almost a year from now.
Putting the power supplies on a Herzan is silly to me. I was thinking of only the pre-amp on a Herzan.
FWIW, Ron, i found greater improvement isolating my power conditioner than isolating the Zanden Transport. A lot of audiophiles who have spent time with isolation originally advised me when i started out to start with the power conditioner and power supplies. While i could understand a tubed power supply like Zanden...i was totally surprised by the improvement in density of tone, separation of images and generally purer signal when we started isolation the Burmester 948 Power Conditioner. Makes 0 sense to me. And I could keep moving the feet around underneath and it would go frustratingly wrong until i found the correct spot and isolation combination. still makes no sense to me.
That is very interesting, Lloyd, and not at all what I would have expected! Thank you for reporting that.
FWIW, the Stillpoints folks typically recommend STARTING with power supplies/power conditioners FIRST among electronics...and then evaluating the use of Stillpoints with other components.
It was a long time ago, but I put an Io with dual power supplies on a Vibraplane. (I know, the Vibraplane dates me!) It made a noticeable improvement, with richer tones, deeper blacks, and better imaging.
Thank you for responding. You put the main Io unit on the Vibraplane, I assume, not the power supplies?
First I heard what the Herzan did with Mike Lavigne's turntable, and I was mighty impressed. I had not thought that such clear and clean bass was possible from vinyl. Then Mike put the Aqua Formula on to a Herzan, and the sound quality was catapulted to another league.
Well the good news is that Sound Test now a dealer for Herzan for Audio applications in the US, Canada, Australia and Israel. If you are in Europe, we can help you too. We pick up our TS-150 from the factory in Switzerland in a weeks time.
You should specify this is based on one set of giants, which you cannot fit under anything other than your power generator
Are Herzans better than Halcyonix (sp?).
Bonzo, I've used the Mooks as I did in London
Both under my cdp on my Symposium rack, and under my transformer in a solid shelf in the flr
Prev in London, the impvts wrought were dramatic w both scenarios
You know how much I raved about them
Here in my new room, they are marginal at best, and in many ways disadvantageous
An Accurion i4 was a boon under my tt back in the flat in the trial I did 3 years ago, it will be interesting to see if effects are limited here when I trial the Speirs active shelf for my tt
My new room is like a lie detector for gear and tweaks, out of five series of tweaks that worked brilliantly in London, two have proved to be superfluous here incl Mooks
Wisnon, I believe Herzan, Halcyonics (Accurion) and Speirs And Robertson are all on a par
All are uber lab grade tech w somewhat similar specs and tech descriptions
Speirs fits the bill for me, being 25% cheaper than the other two, London based so easier re trials and comms, and the platforms are more oversized at not much extra cost
Speirs is a no brainer for my tt, £2k for passive air shelf, a more bulletproof version of Vibraplane, and £6k for full electronic active shelf compared to £8k for Herzan and Accurion i4/Halcyonics
I tried that, but ended up putting the entire stack on the platform. I used Black Diamond shelves in between the units and three large Mapleshade brass weights on the top.
The Giants should not be used under the CDP or the pre as the chassis is too small. When 3 years ago you had brought the CDP to my place and then we had tried at yours we had used Ultras. I don't think they will be as effective under TT as active. Those who have both Vibraplane and Mooks prefer Vibra under the TT and Mooks under the components.
. . . What w all those Io tubes causing vibration, Herzan makes a lot of sense
I understand how the Herzan insulates from external vibration the device resting on it, but how does the Herzan help with vibration generated within the tubes themselves?
