1 ohm amplifiers
Loheswaran
470
125
348
Out of interest - which manufacturers make amps that drive a 1 ohm load?
thanks
Lohan
thanks
Lohan
I have no tests, but understand Gryphon, Vitus should both drive those loads. No doubt there are a number of beast amps that will do so.
I can make one :)
Boulder
CH Precision
Soulution
Jeff Rowland
My Lamms M1.1 have driven my Scintillas beautifully :cool:
It appears the new Pass A25 has "one ohm" potential. 100 watts at 2 ohms, 200 watts at one ohm. The hockey puck transistors have very high power dissipation.
H2O amps were a bit of a boutique class D in the day for Apogees, especially Scintilla. Vince from Sacto (now deceased) was a rabid promotional fan. It seems the modules and topology were changed frequently with constant upgrade-itis, but that was several years ago.
I heard them on Vince's Scintillas, but he was badgering us to fall down in worship. I thought they sounded OK, but not necessarily revelatory.
Hello,
SAC" THe Amplifer" stable under 0.5Ohm 360Watt Class A Danger hot 100 Grad Celsius at the Heatsink(Name Grave Stones);)
T&A 3000 Mono Amp stable under 1 Ohm
The question is somewhat meaningless without a spec for power required. Many amps will drive 1 ohm at low power; even tubes. What are you trying to drive?
1 ohm can only mean the dreaded Apogee Scintilla
