there are pics on my audiogon system link in my signature, which is normally at the bottom of each of my posts, but does not appear in this thread as it's a Taiko forum. i did just take some quick phone pics see below. standing near the racks they do look ugly, but sitting down they are mostly hidden behind the turntables. so it's not quite as 'sore thumb' as my close ups show. my system pics show the long view to get an idea.Mike, where can I see a picture of your “homemade” solution for holding heavy cables?
Great report!
Did Chris offer an explanation for why charging a battery supply with different
Power cables would make a difference?
Did you not have time to try the analog out?
A major reason for this is that a power cable does not feed the Olympus server and IO in isolation. It is connected to the power distributor which is, in turn, connected to other components of the system. This couples earth, and potentially introduces a capacitance. Even if the battery-powered components should be almost indifferent, this still has an impact on the rest of the system. Just connecting a power cable to the power distributor alone, even when not connected to a device, can already have an audible impact.No and No.
All I can say is the immersive effect and 3D feeling with the Masterbuilt Ultra PC was a ginormous step up . I passed this on to Chris who will answer
It looks as if my first audition of the analogue board will be when Emile pays his visit here
Have you had the liberty to experiment with different metallurgies?A major reason for this is that a power cable does not feed the Olympus server and IO in isolation. It is connected to the power distributor which is, in turn, connected to other components of the system. This couples earth, and potentially introduces a capacitance. Even if the battery-powered components should be almost indifferent, this still has an impact on the rest of the system. Just connecting a power cable to the power distributor alone, even when not connected to a device, can already have an audible impact.
Mike is spot on: a power cable is a grounding cable, too.
I'll take two of them, JT!If anyone needs one of these let me know, it can be modified into an audio rack. Shipping might be a little high! I call it safe and sound!
You will have to give me your shelf config. along with your preferred combination number. 15 numbers and letters! I must tell you its holiday time here in NC so things slow down a bit. Actually its always slow here. Oh another aspect contact our engineer team, we will have to shore your floor up. Its part of the special we have been running. I take it you like the industrial look....A fine choice choosing two Michael, Analog for one and digital in the other... Safe and Sound Appreciates your business!I'll take two of them, JT!
Maybe I can buy one of this to support my MasterBuilt Ultra from the OlympusYou will have to give me your shelf config. along with your preferred combination number. 15 numbers and letters! I must tell you its holiday time here in NC so things slow down a bit. Actually its always slow here. Oh another aspect contact our engineer team, we will have to shore your floor up. Its part of the special we have been running. I take it you like the industrial look....A fine choice choosing two Michael, Analog for one and digital in the other... Safe and Sound Appreciates your business!
Is there any shelf space under the IEC??? And if there is aprox. inches...The Taiko gear is about 165 lbs and is centered on the CMS filter so thanks again but that wont work either
Also, get some of the IEC covers mentioned earlier.If there is, a wedge of some sort, small wood block and subsequent thin pieces on top of the wood block until it is firm and level, cardboard folded, anything to keep that support tight under the connection...
I support the very heavy IEC plug and cable weight of the Sablon Prince power cord to my Extreme with dense foam blocks salvaged from packing blocks used to ship electronics equipment. They cut easily to size with a sharp knife, have minimal dielectric effect, and they are basically free.
Good luck.
Steve Z
Thank to everyone for their ideas, however as the saying goes, "necessity is the mother of invention". Big shout out to Steve Z who lit up a few neurons deep in the back of my brainYou know everyone is waiting for Friday shipment notices when there are 10+ messages on a Thursday on how to keep an Olympus plugged in![]()
