I have two fuses in Nagra VPA replaced by two sluggos and all works like a charm. Game over for all aftermarket fuses….
Which slug did you find most appealing?I have two fuses in Nagra VPA replaced by two sluggos and all works like a charm. Game over for all aftermarket fuses….
Huh just one - copper/gold i believe - can’t remember honestly…Which slug did you find most appealing?
Supper Suggo Copper and Gold infused, in my systems.Which slug did you find most appealing?
I've tried the graphene and it gave me a great expanded soundstage and 3D presentation but it veiled the detail and just altered the SQ to something thats just doesn't work for me. I have to try other slugs, I guess. Either that or it just doesn't have the same magic for AtmaSphere amps. I know I was never able to get any benefit from upgraded fuses on that amp.Supper Suggo Copper and Gold infused, in my systems.
The copper was better in my X200 Tube IAI've tried the graphene and it gave me a great expanded soundstage and 3D presentation but it veiled the detail and just altered the SQ to something thats just doesn't work for me. I have to try other slugs, I guess. Either that or it just doesn't have the same magic for AtmaSphere amps. I know I was never able to get any benefit from upgraded fuses on that amp.
So ???
Are all of your slugs the Super Sluggo (high purity copper immersed in gold)?The copper was better in my X200 Tube IA
I only have the Supers on my gold note PA 10 amplifiers. My X200 has the copper and I tried the gold immersion on the x200 and preferred the copper. YMMV.Are all of your slugs the Super Sluggo (high purity copper immersed in gold)?
I just starting breaking in a SDFB with Super Sluggo on the LPS driving my internet ONT/Router. A substantial improvement.
I am running a rhodium plated tellurium copper slug in my Gold Note IS-1000 Deluxe Integrated.I only have the Supers on my gold note PA 10 amplifiers. My X200 has the copper and I tried the gold immersion on the x200 and preferred the copper. YMMV.
This list shows the conductive order of some commonly used metals and alloys, based on equal sizes.I am running a rhodium plated tellurium copper slug in my Gold Note IS-1000 Deluxe Integrated.
Rhodium is a platinum and not a great conductor however is very resistant to corrosion and wear. This table is not taking into consideration hybrid alloy blends and their properties. I have steered away from the lower ranked materials unless durability (wear and corrosion) are a factor in the application. I do not have any Rhodium treated power cables in my systems. Copper or Silver. YMMV
- Pure silver
- Pure copper
- Pure gold
- Aluminum
- Zinc
- Nickel
- Brass
- Bronze
- Iron
- Platinum
- Steel
- Lead
- Stainless steel
Yes I found that the SS Copper/Gold infused better in my GaNfet Amplifiers than the Copper, It was the exact opposite in my Tubed Integrated system the Copper was much better than the Copper/Gold infused.Useful list. All my experience with rhodium is that it strips warmth from the sound. Silver I shy away from, or limit, for similar reasons or brightness, although I don’t recall ever hearing pure silver. For those reasons I prefer as pure, high grade copper as possible, although the copper sluugo isn’t quite making it (yet) for me, in spite of its attention to detail.
I think people are going to find that system synergy is going to key and different alloys will have different sound characteristics. As MacF found with his system. It is process.
You can shorten the process with Taguchi arrays...It is process.
I rather enjoy the process that is half the fun.You can shorten the process with Taguchi arrays...
Horses for courses! I just like to quickly get to the best sound so I can enjoy it!I rather enjoy the process that is half the fun.
