@Taiko Audio
Hi Emile,
I finally have some free time...
So I'm preparing for the installation of my Olympus + Omlympus I/O XDMI :)
As there have been a few changes, I was wondering how I should power the various components.
To power the Taiko Switch + Router + DC Distributor I have a PlixiR Statement.
Each of my audio components have their own socket+cable+breaker.
But I only have 4 sockets (I didn't plan for more when I built my listening room...)
So one socket has to be shared.
What setup would you recommend?
Here's a diagram:
Hi
This is wrong.
1. Use one phase only for all sockets
I tested this and if you use 3 phases is sounds odd.
2. Never . I repeat. Never brake neutral.
This should be connected to main neutral.
3. Do not pass neutral from one to the other. You must have individual wires ( just like phase wires).
4. Please make sure to run individual grounding wires from sockets to the main ground.
5. If you want to use Doepke 63Amp ( I use identical) with 3 individual connections you simply ask your Electric Expert to run all 3 from L1 (all of them will be from selected phase)
6. Never connect it yourself. It MUST be an expert connecting it.
Selection of the components is perfect !
I use those and tried everything else before.
Good choice !
Alternative in wall wire is Oyaide 5.3 mm2
Reactions: Taiko Audio
Of course, it is an enigma how Stavros is going to solve the connection of that “box” to the DAC. And I say that it is an enigma, because I am absolutely convinced that it is not going to do the enormous nonsense of converting the XDMI signal into USB or AES/EBU and that is exactly where the enigma lies.
Just speculating.....
If the receiver for AES/ebu is software based, and can be modified in the DAC, the external box could re-use the XLR based connection, with a standard or special new cable, to decode xdmi to a proprietary format carried on the XLR. Just thinking out loud
Reactions: JYACO
@Taiko Audio
Hi Emile,
Here's a diagram:
I agree with @Kris .
Although there might be more behind your diagram then meets the eye, being aware you tend to research things thoroughly you may already have taken this into account but here's my opinion anyway:
You want to split power your paths as close as possible your devices to minimize your ground loop areas, aka use a power strip close to your devices. Obviously this can also be multiple wall outlets tied together. A ground loop area is for example defined by 2 devices, the interconnect between them, and the 2 power cords containing the ground conductors to the point where those meet. If that is all the way to your distribution box the areas will be unnecessarily large. Now you could run a single ground and split that close to your equipment, and perhaps do the same for your neutral as that is connected to ground somewhere as well, but then you create odd situations for where your return currents would "like to travel", being as close as possible to your live conductors.
This is for example the reason for modern PCB designs to use ground planes in stead of star grounding etc. Return currents can travel where they prefer to travel, there are no obstructions, resulting in overall lower EMI.
It just presents the music more accurate in every aspect.
Not sure why is that (processing speed ?)
But it makes a very significant difference.
You should try also the Android phone
I used Samsung .
It is also extremely good.
I hope Taiko Team will investigate that and propose best solutions we can use or buy.
We have investigated that, and it appears to be more about software then hardware.
I'm an apple IOS user, so I'm approaching it from that angle, but it should work similarly for Android:
If you're "suffering" from a high levels of "audiophile nervosa" and financial expenditure and/or environmental impact is off less importance to you, a dedicated tablet with a dedicated apple ID account is the way to go. You can uninstall as many apps as possible, disable background activity as much as possible, and exclusively use this device and ID to control your server. I don't feel the age (/performance) of the remote device matters that much in this scenario.
If you have an IOS device which you use for other purposes, sharing your apple ID with your other devices, with multiple apps, it will sync your data, creating network traffic overhead, which can be audible to a degree. The most extreme case would for example be if you went on an Holiday, took a lot of photos/videos with your IPhone, return home, power on your Ipad, don't have it configured to use Icloud exclusively for your photo content, turn it on, and it will start downloading all those photos/videos in the background while you're listening to music. All your apps and information will be synced to all your devices when you use the same apple ID, apple health, imessage content, whatsapp content, etc etc.
Now if you own the Taiko router, this influence will be reduced but will still be audible depending on the actual amount of traffic generated, however, you can also choose to connect your Ipad to the upstream router's Wi-Fi, NOT your Taiko Router Wi-Fi, and these effects will be irrelevant again as your upstream router will be processing this traffic in stead of your Taiko audio network Router...
Lastly you can choose to ignore all of this of course, which is arguably the healthiest approach, and I don't feel it's actually that significant, but yes, there's ultimately a detectable difference :)
Emile's answer:
Audio Nervosa? I certainly wouldn’t know anything about that…
(asking for a very close friend)...
No wifi use, all fiber and lan cabling in network.
Currently lan cables connecting Taiko Router to iPad controller and a computer.
If he changes connection of iPad and computer to a switch just upstream from the Taiko Router, will that isolate the iPad network activity from the Taiko Router (even though this Switch and Taiko Router are connected)?
And this would be as effective as having a separate Apple ID for the iPad?
My Apple tablet is in my music room and is only on the Taiko audio network with the Extreme and nothing else upstream to that. I never use my iPad for anything but the XDMS control app. Never an issue for me as a result
Emile's answer:
I think you miss my point. The AES format would not be used, but the XLR connector might be used to transmit a different proprietary format....a similar approach might use the unbalanced coax
I don't think so. I asked about the input, not the format. And Emile mentioned that AES will not be used.
AES is an input format. It uses an XLR connector. That connector could be used for something else that has nothing to do with AES.
Reactions: cat6man
Good point.
Ground loops are very common.
What about power hungry amps if manufakturer advices to use a separate powerline for each amp?
One of the most frequently asked questions I get as a Taiko dealer when I discuss the Olympus XDMI is:
"How can that little DAC card play at the level of the big DACs?"
To address this, I will use a photo of the Audio Note Kits DAC 5.1. It's a tube DAC that I have built and owned 6-7 years ago.
(these are stock photos from their website as I was too lazy to find mine)
At a very high level, we have three main sections in a DAC like this one - power supply, analog section, and digital section.
Power Supply:
There are many power supply designs. They can be switching mode or linear, regulated or unregulated, one rail or multiple rails. For a regulated linear design, you generally have a transformer, rectifier, filtering capacitors, and regulators. You may have multiple rails, multiple transformers, chokes, etc. Rectifiers can be vacuum tube rectifiers, diode-based, FET based, GaN-FET based, etc. I can't really list all of the variations and that's not the purpose of this post.
The ANK5.1 power supply has transformers, rectifiers (vacuum tube rectifier on the B+ and diodes on the rest), chokes, capacitors, and regulators.
I have highlighted the power supply on the ANK 5.1 DAC below:
Analog Section:
I'm not going into too many details here either as there are many ways you can design an analog section.
In the case of the ANK DAC, there are I/V transformers, a tube section, and output transformers.
I have highlighted the analog section on the ANK 5.1 DAC below:
Digital Section:
The digital section in this particular DAC (and many chip-based DACs) is very simple.
The green board on top is a USB to I2S converter. The converted signal goes to the bottom red PCB.
I have highlighted the digital section on the ANK 5.1 DAC below:
So the entire digital section is that little red board there. Let's zoom more into that digital board (okay, I had to dig out photos from my own build for this):
About two-thirds of the circuitry you see on the top is for the relay switching between S/PDIF and USB, powering those relay switches, and converting the S/PDIF to I2S. Only a very small portion of the circuitry around the AD1865NK chip has anything to do with the digital to analog conversion. BTW, this DAC weighs 30 lbs, and as you can see only a few small components around the DAC chip are responsible for the D to A conversion. I hope this clearly illustrates how simple the Digital to Analog conversion with a DAC chip can be.
So back to the the question - how does this compare to XDMI?
XDMI Power supply - The Taiko BPS is one of the pinnacle technologies for Taiko. I've heard some comments about the BPS that I cannot share publicly, but this should be as good as anything else out there, regardless of the cost.
XDMI Analog section - Not a lot has been shared publicly about the analog section of XDMI. It's a lot smaller than what you see on the ANK5.1 photos but it uses solid-state components. I happened to see several prototypes of the XDMI analog section and was privately told that when you power these with a BPS, the results were both surprising and shocking. And that has led to some unexpected outcome that has satisfied Emile's requirements. So it all comes down to implementation rather than technology.
XDMI Digital section - that's the secret sauce, and I know absolutely nothing about it (other than it's using a ROHM DAC chip). But from the very few publicly posted photos, these 6-layer PCBs look a lot more sophisticated than the 2-layer PCB you see on the ANK5.1 (which is very similar to what some very expensive tube DACs do).
So, can that little dac card play at that level of the big DACs?
IMO, not only it has the potential to play at the level of the big DACs but also to potentially play better than them due to the innovative way of extracting audio and the BPS. Oh, and that ROHM chip, if implemented properly (should I mention that Emile's standards are much higher than mine), is crazy good!
Well, what about the lack of a huge elaborate tube-based analog section? XDMI can in no way deliver the same sonics as let's say a Lampizator Horizon?
I absolutely agree with that! It can't! I am hoping that the simple solid-state output powered by a BPS is very transparent and gets out of the way. All I need that section to do is to add some gain to the DAC chip analog output and reduce the output impedance as transparently as it can, so I can connect it to a really good tube preamplifier with RCA interconnects. In fact, I would not be surprised if it's a lot more transparent than tube DACs (but lacking the tube magic which I will add in the preamp).
Others will be using the Lampizator XDMI connection. I would love to hear that in my system in the near future too.
I've had some discussions with Lucasz. The two things I gathered from these discussions were that he was very excited about XDMI and that he has done a lot of good work on the Horizon digital section.
I will have a much better understanding once I receive my Olympus XDMI and spend some time testing it in my system. Until then, the question 'Can it?' has a straightforward answer: 'Yes, it can.' However, the question 'Does it?' will remain unanswered until I've had the chance to evaluate it personally.
BTW, here is a digital section implementation with the same DAC chip (actually 48 of these chips) as the ANK5.1 DAC that is on a completely different spectrum of complexity. As simple as the ANK5.1 digital section is with just a few components, this one seems crazy complex. I won't even pretend that I understand what was done here:
I was a huge fan of the AD1865NK DAC chip until I heard a well implemented ROHM DAC. But as I said in my previous post - it's all about the implementation.
To be honest - I haven't heard a DAC with 48 of these AD1865NK DAC chips. I probably will, once Aries Cerat start offering XDMI.
Power Supply:
Analog Section:
Digital Section:
This has been my contention for quite some time.
When analyzing the subsystems, if you will, that make up a stand alone DAC, the Taiko Olympus compares very favorably. Regardless of what you look at -- chassis/vibration control/EMI shielding, power supplies, digital section, analog section -- Taiko's implementations are at least as good as anyone else's and in some cases, arguably superior (power supplies and regulation). And that is before considering XDMI.
I posted a picture of the interior of my dCS Vivaldi APEX DAC a while ago:
Circled in yellow is the real estate devoted to the analog output stage. A couple of square inches at most.
Like Vassil, I don't need or want my DAC to be the vehicle for "tube goodness" -- I can accomplish that with my tube preamps or tube amplifiers, apologies to Lampizator owners. As long as it is neutral and transparent and to paraphrase the late Steve Jobs, insanely great, I'll be happy.
Steve Z
That’s hard to predict, replacing the Taiko Wi-Fi for a presumably RJ45 cable increases power consumption of the Router (a rj45 port consumes more power then the internal Wi-Fi module).
Upstream traffic would go from WAN to LAN, it has a bit more overhead then from LAN to LAN.
But yes it would make traffic generated by the iPad irrelevant (outside of Roon’s traffic ofcourse).
Reactions: wil and ctydwn
If RJ45 is so power hungry why we don't have 2 sfp ports in Taiko router like we have in Taiko switch ?
One dedicated to WAN second to LAN.
Dream Machine pro has 2 SFP ports so theoretically it would make a sense to connect it by the DAC cable instead of RJ45 to SFP WAN port in Taiko Router.
Idea for Gen 2 Taiko Router or irrelevant difference in your testing ?
