Quite a departure from your previous designs - visually. How does the amplifier design differ, if you wish to mention?Hi!
The Intrepid Amplifiers are finished. My new TOTL amps, all silver transformers, custom tubes, solid block chassis.
Some info on my blog:
Intrepid Amps
Best regards
Thomas
Hi!Quite a departure from your previous designs - visually. How does the amplifier design differ, if you wish to mention?
The setup is explained in my blog post about the High End:@VinylSavor
What will be your set-up in Munich together with Admire Audio?
Thanks,The setup is explained in my blog post about the High End:
https://vinylsavor.blogspot.com/2024/04/high-end-2024.html
We will play digital sources only off line either from a laptop or from a CD Player. However we can play music from a stick if you want to bring your own. I will try to get an extensive library ready for the show. We will of course also play vinyl (probably 50% each vinyl and digital). Visitors can bring their own records too.Thanks,
what will you use as source upstream to your Intrepid DAC?
Will it be possible to listen to music from streaming services like Qobuz or Tidal?
Two years ago Admire Audio provided music from streaming services which was very convenient.We will play digital sources only off line
We are discussing that and if possible we will set it up. but just to be on the safe side there will be a off line library.Two years ago Admire Audio provided music from streaming services which was very convenient.
Maybe you can ask them to arrange the same this year.
Thanks for the link.The setup is explained in my blog post about the High End:
We will mainly use the Intrepid amps and preamps. There will be a full set of Heritage products on display and will also be demoed if there is interest. There will also be a variety of Compactron amps, preamps and DAC. However we will not be constantly swapping amps and preamps. If there its interest we will do separate sessions with Heritage and Compactron products at certain time slots.
Best regards
Thomas
