Thats a lot of hardware to be shipping from Holland to Southern California. My hope is to have option 4 at my house
I volunteer my dining room table as a staging venue in San Diego for all us SoCal types
Wow, I was not expecting changes and offerings of this magnitude. For those of us with more modest ambitions, do you expect to release something like TACDA as initially described months ago: a card with RCA analogue outputs that can be installed by the user of the Extreme? In other words, a DAC internal to the Extreme that would replace the USB interface? And if so, when could we expect pricing information on that?
is this also the connection between the Extreme and the IO?
that is 40Gb/s?
and DAC (direct access connect) copper, as with the switch?
Any update on the (upcoming?) MSB Pro-ISL etc connection to the Olympus?
I have one last question that also needs answering. In light of the trade up pathway, I did ask about the redundancy of the Taiko USB card but so also is there a redundancy with the DCD which no longer will be needed . Is there a trade back pathway for those two items as well
If Steve has the shelf space for that, I don't see why notDear Emile, Will we be able to compare the sound of options I (Extreme), II (Extreme + O I/O), and III Olympus at Steve's place? When?
That would be very helpful in deciding which option to purchase.
This is very helpful, understanding the exercise is difficult.
Curious what relative percentages could be ascribed to the Taiko switch and router in addition to these percentages?
Do the switch and router have the same/less/more impact with the Olympus and/or IO than they have had with the current Extreme? (Fwiw - I'd say the combined switch/router/power distributor 'bundle' added ~40% to the Extreme).
Congrats on these gorgeous looking and technically mind blowing products! Whew alot to digest…
Ahh - bummer...Unfortunately XDMI cannot simply be mounted inside the Extreme and perform well. We ended up optimizing it around being powered by our battery power supply solution. It is a very sophisticated design, it's performance is significantly by how it's implemented.
It's nice that an Extreme owner can upgrade to Olympus IO now, then later upgrade to full Olympus and still have use for the IO box, but what is it about Olympus IO that also improves Olympus? Something about battery power focused exclusively on interface cards (like we used to plug an external LPS into an external DC input on a PCIe card)?
It all makes sense Nenon. Thanks for the response. Out of curiousity, how many boards are custom in the Olympus?
God help my bank account. I really like this (makes me think of it broadly as a peer to what MSB did with the Digital Director)
Hi Emile, I am using Merging Ravenna. Is there any benefit upgrading to Olympus if I intended to continue using Ravenna? The reason is that I have digital XO and I am using Merging Hapi with 9 channels DAC
@Taiko Audio
Hi Emile!
That's quite an announcement!
Are there any plans to make a single box?
Something like :
Olympus + Olympus I/O = Olympus Apex
That would be nice (less cables, les boxes,...)
If not, will Olympus and Olympus I/O be stackable?
I was expecting a design close to that of the switch or router.
What material is used for the chassis?
I look forward to your next announcements.
Cheers,
Thomas
Do I recall correctly you are using 2 network cards?
1. Is the Olympus still based on Windows Server OS?
2. How the umbelical cable receiver is to be installed on the Extreme for connecting it to the Olympus I/O?
3. Is the option of installing a BPS + XDMI card in the Extreme chassis (instead of getting the Olympus I/O) still on the table?
4. Can the XDMI card be obtained in such a way that it has BOTH analog and digital output?
