Is it me or am I seeing more and more people using seperate power supplies for various components? Is this really necessary or just another marketing ploy to get us to part with dollars?
John
John
Methinks it's both
I don't believe it to be detrimental. Isolation of the power supply is a plus.
My Lamm LL1 Signature preamp is a dual mono 4 chassis preamp each channel having it's own separate power supply
seems so.
There is also some possibility of mechanical vibrations from the power transformers due to movement of the coils and magnetostriction (bulk expansion and contracton of magnetic material in a magnetic field). These mechanical vibrations can transfer noise to the signal circuit.
What is that, pray tell?
Rich is correct; you have to have seen the '50s sci-fi movie "Forbidden Planet"
which gave Dan D'Agostino the idea for the name of his company; "Krell".
Krell metal is very dense and has a high heat capacity so that even the "blaster"
of Commander Adams can't damage it or even heat it up. See second picture
down at:
http://www.umich.edu/~umfandsf/film/promise/forbidden-krell-tech.html
You can watch what happens to the Krell metal at the end. SPOILER ALERT:
This video clip gives away the identity of the mysterious force that is killing
members of the crew.
http://www.youtube.com/watch?v=GQwmKClCAbQ
Greg
Curious as to who the "we" is that knows an ARC LS-10 is better than a Ref 3?? I am going to take a wild guess and say you modded the snot out of it. If so, what did you do? How do you know that a larger power supply would improve your Sansui tuner? A tuner is not swinging much voltage nor is it carrying a lot of current. When you do your mods to your gear, are you making any actual circuit changes or just parts swapping?Larger and separate Power Supplies can have a definite benefit to the performance. As Steve has mentioned in the case of his Lamm amps, the top of the line Krell Evolution monoblock amps and Preamp this is true. The same is true for my Teres Certus 450 Turntable, Soundsmith Strain Gauge 410 Phono Preamp, and the Audio Alchemy DTI PRO32 jitter reducer that I am getting. This is also true of the Anniversary ARC Preamp. My upgraded ARC LS10 Line Stage Preamp may well perform as well as a stock Reference 5 (we know that it is better than a Reference 3, but I do not know how it compares to the Anniversary Preamp). I know that a larger power supply would improve my modified Sansui TU-9900 AM/FM Tuner. I know that in general monoblock amps sound better than stereo amps. I know that my upgraded (modified) Aragon Palladium 1K power amps are much better than stock and most any amp that we have compared them to, but again, I am not sure how they would fare against some of the amps with the separate Power supplies.
Rich
