Lyra Atlas Pics
XV-1
4,203
4,008
2,520
Sydney
I recieved my Lyra Atlas today. s/n 22. Only played a few LP's so far. I have just 3 words at the moment - Speed, Dynamics, Purity :D :cool:
Hope you enjoy the few pics of this new cartridge.
Yea, plenty. the manual is very detailed with loading recommendations based on the total capacitance of your tonearm. Anyone know the cap of a Graham Phantom?
Specifications for LYRA ATLAS
Designer: Jonathan Carr
Builder: Yoshinori Mishima
Type: Medium weight, medium compliance, low-impedance moving coil cartridge
Stylus: Lyra-designed long-footprint variable-radius line-contact nude diamond (3um x 70um), slot-mounted
Cantilever system: Diamond-coated solid boron rod with short one-point wire suspension, directly mounted into cartridge body via high-pressure knife-edge system
Coils: 2-layer deep, 6N high-purity copper, cross-shaped chemically-purified high-purity iron former, 4.2ohm self-impedance, 11uH inductance
Output voltage: 0.56mV@5cm/sec., zero to peak, 45 degrees (CBS test record, other test records may alter results)
Frequency range: 10Hz ~ 50kHz
Channel separation: 35dB or better at 1kHz
Compliance: Approx. 12 x 10-6cm/dyne at 100Hz
Vertical tracking angle: 20 degrees
Cartridge body: One-piece machining from solid titanium billet, with reduced-surface higher-pressure headshell contact area, predominately non-parallel and asymmetrical shaping, phase-interference resonance-controlling mechanism, and body threaded directly for mounting screws
Cartridge mounting screws: 2.6mm 0.45 pitch JIS standard
Distance from mounting holes to stylus tip: 9.5mm
Cartridge weight (without stylus cover): 11.6g
Recommended tracking force: 1.65 ~ 1.75g (1.72g recommended)
Recommended load directly into MC phono input: 104ohm ~ 887ohm (determine by listening, or follow detailed guidelines in user manual)
Recommended load via step-up transformer: 5 ~ 15ohm (step-up transformer's output must be connected to 10kohm ~ 47kohm MM-level RIAA input, preferably via short, low-capacitance cable)
Recommended tonearms: High-quality pivoted or linear (tangential) tonearms with rigid bearing(s), adjustable anti-skating force, preferably VTA adjustment
This might be the most SRA sensitive cartridge ever built because of Lyra's new "angle" technology. If that ain't right, then the coil won't line up correctly.
Thanks. I see they (specs) are typical of cartridge manufacturers.
I like moving coil myself as well.
Tom
This is an example of where specs are deceiving. The Atlas is a very special cartridge and time will tell if Jonathan has hit a home run with his latest design. For instance, Jonathan has reduced the mass of the coils by 40% and upped the output voltage by 20%. Pretty neat trick and the reduced mass should lead to a lot more resolution. Also, the way the generator mechanism is assembled, reduced standing waves and vibrations within the cartridge. Not sure what spec would tell you that. Also it's an X-shaped coil former and that brings with it some advantages over the more conventional rectangular or square shaped former eg. channel balance.
Jonathan also obviously found some of his ideas, like having a polycarbonate or air former too hard to implement with the Atlas. The Atlas is supposed to be a bitch to build and Mishima listens to every cartridge before it's sent out.
Now where the hell is mine? :)
You installed in the Phantom or Supreme?
Looking forward to future installments!
Plain old Phantom Myles. I should upgrade to the supreme just for the spirit level.
I am sure yours is not too far away:b
Yeah I hate to be too pushy with the distributor :)
Hopefully in the same shipment as mine! :)
To the OP: Nice pics, but it seems that Lyra no longer use real wooden boxes for their cartridges... :-(
I had the helikon many years ago. Can't remember if that had wooden box.
Kleos has similar box to the Atlas. I like the current box and packing to be honest. Works very well and very safe for shipping.
I just hope I get mine before the Mayan Calendar runs out. Green. My University color is green. :)
Thanks for sharing, great pics.
I was looking to purchase a Olympos cart at one point but could not find one. I find this hobby funny because as soon as this new design was released now there are three availble and at very nice attractive pricing.
I read on another forum Jonathon mentioning this new Atlas surpases the Olympos by allot, I look forward to reading from others their thoughts along with hearing one for my self.
Could be a nice ad on to my set-up :D
I'm sooo jealous. :)
I just have a humble little Argo(i) but it sounds wonderful.
Me too--well, having my Parnassus converted into an Olympos SL.
It was Jonathan's comments to me on Audiogon vis a vis the Olympos SL vs Atlas that convinced me to put my Olympos plans on hold for now and go for the Atlas. But I'm hanging onto my Parnassus so that an Olympos Sl remains a possibility... :)
Thanks for the nice thoughts gents
can someone tell me if that is a piece of masking tape on the bottom of the cartridge and is it just left there as I noticed it on the mounted arm
